Home » Modeling » EMF » EMF 2.9 and RAP 1.5
EMF 2.9 and RAP 1.5 [message #1012480] Thu, 21 February 2013 11:32 Go to next message
Lothar Werzinger is currently offline Lothar Werzinger
I have a RAP 1.5 application and I tried to create a target platform based on the latest Kepler milestone to get a newer version of CDO and EMF.
As I don't want to make the transition to RAP 2.0 immediately I created the target platform with RAP 1.5 instead of RAP 2.0.
Everything in my application compiles fine, but when I try to build the product it fails, as the EMF RAP plugins (org.eclipse.emf.rap.common.ui and org.eclipse.emf.rap.edit.ui) depend on RAP 2.0 as the minimum plugin version.
This dependency is the only thing that prevents me currently from using CDO 4.2 and EMF 2.9 with my RAP 1.5 based application.
Is RAP 2.0 really required as the minimum plugin version or could the plugins work with RAP 1.X as well? If the plugins don't need 2.0, can the version range be changed, so that one can build RAP 1.5 Applications with EMF 2.9?
Thanks in advance!
Re: EMF 2.9 and RAP 1.5 [message #1012695 is a reply to message #1012480] Thu, 21 February 2013 22:39 Go to previous message
Ed Merks is currently offline Ed Merks
Lothar,
I think the changes we made should allow it to continue to work with 1.5
http://git.eclipse.org/c/emf/org.eclipse.emf.git/commit/?id=6246af91070f7f0520dfa831ad5c37dc8b8bbbbe
http://git.eclipse.org/c/emf/org.eclipse.emf.git/commit/?id=942c099f3f5aa8e6ef6d9d1bc4d752fbd74894ca
But I'm not sure if Dennis is building against 2.0 or against 1.5
https://bugs.eclipse.org/bugs/show_bug.cgi?id=387180
The build inserts the bounds, so it sounds like he's building against
2.0 if that's what you're seeing as the lower bound.
In general, because RAP has broken APIs, you should expect that
frameworks using it will similarly need to make incompatible changes,
although that's not the case for EMF's RAP support.
> EMF.
> Thanks in advance!
Previous Topic:[Teneo] Errors when deploying teneo 2.0.1 + hibernate 4 in JBoss 7
Next Topic:[CDO] Problems with XML Import
Current Time: Wed Jun 19 12:45:25 EDT 2013
Powered by FUDForum. Page generated in 0.01340 seconds
