Home » Modeling » EMF » [CDO] Tables in DB without Primary Key
icon5.gif  [CDO] Tables in DB without Primary Key [message #1012472] Thu, 21 February 2013 16:12 Go to next message
Marc Gil is currently offline Marc GilFriend
Member
Anybody (Eike? Very Happy ) knows why the tables of the DB have not any Primary Key? CDO_ID columns is not a good candidate to be a primary key?
Thanks Smile
Marc
Re: [CDO] Tables in DB without Primary Key [message #1012584 is a reply to message #1012472] Thu, 21 February 2013 20:50 Go to previous messageGo to next message
Stefan Winkler is currently offline Stefan WinklerFriend
Hi Marc,
which DB are you using?
We are, in fact, using the pair of cdo_id, version as primary key for
most tables. If this is not the case for you, then maybe there's a bug
with one of the DB adapters.
Stefan
Am 21.02.13 17:12, schrieb Marc Gil:
> Anybody (Eike? :d ) knows why the tables of the DB have not any Primary
> Thanks :)
> Marc
Re: [CDO] Tables in DB without Primary Key [message #1012617 is a reply to message #1012584] Thu, 21 February 2013 22:29 Go to previous messageGo to next message
Member
Hi Stefan,
I'm using postgreSQL 9.1, and I have not seen any table with a defined Primary key... Maybe it's a bug, I don't tried other databases like mySQL or Derby.
Marc
Re: [CDO] Tables in DB without Primary Key [message #1014321 is a reply to message #1012617] Mon, 25 February 2013 15:30 Go to previous messageGo to next message
Hi Marc,
this seems like a bug in the PostgeSQL DBAdapter.
Please open a Bugzilla for this.
Stefan
Am 21.02.13 23:29, schrieb Marc Gil:
> Hi Stefan,
> mySQL or Derby.
> Cheers,
> Marc
Re: [CDO] Tables in DB without Primary Key [message #1014661 is a reply to message #1012617] Tue, 26 February 2013 08:27 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 21.02.2013 23:29, schrieb Marc Gil:
> Hi Stefan,
Do you see unique indexes on the ID columns (or ID+version pairs)?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Tables in DB without Primary Key [message #1048229 is a reply to message #1014661] Wed, 24 April 2013 07:39 Go to previous messageGo to next message
Member
Hi Eike,
Yes, I see an index in PostgreSQL, but there is no explicit definition for the PK. Nevertheless, in MySQL there appears the PK for any table.
Another question: There exist any possibility to specify (for instance, via the Store) that a unique restriction should be created for a column or a set or columns in a table? Maybe taking into account the Unique restriction in the attribute of the metamodel...
Marc
[Updated on: Wed, 24 April 2013 07:39]
Report message to a moderator
Re: [CDO] Tables in DB without Primary Key [message #1051739 is a reply to message #1048229] Mon, 29 April 2013 07:07 Go to previous message
Am 24.04.2013 09:39, schrieb Marc Gil:
> Hi Eike,
For the first time I was able now to install PostgreSQL 9.2.4 on my Windows box and would like to test with it. Can you
please submit a bugzilla and attach all the infos you've given here. Please also note the exact CDO versions that your
DB was first created with and that it's now being used with.
No, the DBStore should automatically create unique indexes or primary keys where applicable. And with this fix it does
so now:
401763: Make CDO Server more robust against data dictionary changes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401763
Cheers
/Eike
Previous Topic:[Databinding] EMF and JFace Master/Detail Databinding going in the wrong direction
Next Topic:[CDO] CDOServer throws "The object is already closed [90007-168]" errors with H2-DB
Current Time: Mon Apr 23 21:27:19 GMT 2018
Powered by FUDForum. Page generated in 0.02121 seconds
