Home » Modeling » Epsilon » [EGL] Expected to return a Set, but returned a class
[EGL] Expected to return a Set, but returned a class [message #1012416] Thu, 21 February 2013 09:27 Go to next message
Patricia Fernández is currently offline Patricia Fernández
I created an .egl file (called OperationsC.egl). It includes, simplified version, this operation:
@template
operation currentPackages(): Set {
	var packages : Set;
	for (pack in Package.all) {
		packages.add(pack);
	return packages;
I have another .egl file where I want to use that operation:
import "OperationsC.egl";
var packages : Set;
packages = currentPackages();
packages.println();
But it's not working, giving me this error: currentPackages is expected to return a Set, but returned a class java.lang.String
I checked that the operation I created returns a Set and it does. I can't see what I'm doing wrong, if someone could help me... Thanks in advance!
[Updated on: Thu, 21 February 2013 09:30]
Report message to a moderator
Re: [EGL] Expected to return a Set, but returned a class [message #1012427 is a reply to message #1012416] Thu, 21 February 2013 09:41 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Patricia,
I believe that @template operations always return a string. To make this work, you'll need to remove the @template operation.
Dimitris
Re: [EGL] Expected to return a Set, but returned a class [message #1012428 is a reply to message #1012427] Thu, 21 February 2013 09:41 Go to previous messageGo to next message
"remove the @template operation" should read "remove the @template annotation" instead...
Re: [EGL] Expected to return a Set, but returned a class [message #1012429 is a reply to message #1012427] Thu, 21 February 2013 09:43 Go to previous message
Thank you so much Dimitris, works perfectly now.
Previous Topic:Palette configuration using Eugenia
Next Topic:issue need your urgent attention regarding EVL constraints
Current Time: Sat May 25 14:21:09 EDT 2013
Powered by FUDForum. Page generated in 0.04366 seconds
