Home » Eclipse Projects » Remote Application Platform (RAP) » Rap 2.0 M3 issue with IE 8
Rap 2.0 M3 issue with IE 8 [message #986442] Tue, 20 November 2012 12:48 Go to next message
Avrajit Chatterjee is currently offline Avrajit ChatterjeeFriend
Member
Hi ,
We are using IE 8 and RAP 2.0 M3. We are getting the below error when we launch the application in IE.
Your browser or browser-setup is not supported.
Please use one of: IE 7+, Firefox 3.5+, Safari 4+, Google Chrome 7+ or Opera 10+.
Ensure that Javascript is enabled and XMLHttpRequests are allowed.
Any clues?
Re: Rap 2.0 M3 issue with IE 8 [message #986634 is a reply to message #986442] Wed, 21 November 2012 09:25 Go to previous messageGo to next message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
It works fine for me in IE8 in 32bit Windows XP and on a IE9 in IE8-mode
in Windows 7 64bit. What's your setup exactly?
Also, to find out what's going on, could you please open the IE
Developer Tools (F12), go to the "Console" tab, and type the following
commands:
rwt.runtime.System.getInstance()._isBrowserSupported()
rwt.runtime.System.getInstance()._isModeSupported()
rwt.runtime.System.getInstance()._isXHRSupported()
rwt.client.Client.getEngine()
rwt.client.Client.getVersion()
The results should be true, true, true, "mshtml" and 8.
Greetings,
Tim
Am 20.11.2012 13:48, schrieb Avrajit Chatterjee:
> Hi ,
> Your browser or browser-setup is not supported. Please use one of: IE
> Any clues?
Tim Buschtöns
Twitter: @EclipseRAP
Re: Rap 2.0 M3 issue with IE 8 [message #986737 is a reply to message #986634] Wed, 21 November 2012 13:48 Go to previous message
Member
Thanks a lot Tim. I got the issue by using the console commands that you mentioned. rwt.runtime.System.getInstance()._isXHRSupported()returned false.
I enabled native XMLHTTP support in options in IE and the problem got solved. Thanks for sharing very important piece of debugging ways.
Previous Topic:RAP 2.0 tool issue
Next Topic:Html markup support
Current Time: Fri Jun 22 04:03:00 GMT 2018
Powered by FUDForum. Page generated in 0.02467 seconds
