Home » Eclipse Projects » Nebula » Link for CDateTime properties file broken
Link for CDateTime properties file broken [message #886048] Thu, 14 June 2012 06:01 Go to next message
Alexey Romanov is currently offline Alexey RomanovFriend
http://www.eclipse.org/nebula/widgets/cdatetime/cdatetime.php?page=i18n contains a link to the properties file http://dev.eclipse.org/viewcvs/viewvc.cgi/~checkout~/org.eclipse.swt.nebula/org.eclipse.swt.nebula.widgets/src/org/eclipse/swt/nebula/widgets/cdatetime/messages_en_US.properties?rev=1.4&cvsroot=Technology_Project which produces 404 error code. It should also mention which encoding needs to be used (I assume ISO 8859-1, as for other Eclipse localization).
Re: Link for CDateTime properties file broken [message #886145 is a reply to message #886048] Thu, 14 June 2012 10:27 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Thanks! It has been fixed.
Re: Link for CDateTime properties file broken [message #886151 is a reply to message #886145] Thu, 14 June 2012 10:35 Go to previous messageGo to next message
Could you explain what does {0,date,EEEE} mean? I know 0 means first parameter, but not the other two.
Edit: ah, just SimpleDateFormat. Ok, I'll test my Russian translation and submit it when time allows.
[Updated on: Thu, 14 June 2012 10:47]
Report message to a moderator
Re: Link for CDateTime properties file broken [message #886171 is a reply to message #886151] Thu, 14 June 2012 11:30 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Did you read the documentation of MessageFormat - there all formats are
explained and or linked e.g. DateFormat which points to SimpleDateFormat.
Tom
Am 14.06.12 12:35, schrieb Alexey Romanov:
Re: Link for CDateTime properties file broken [message #886175 is a reply to message #886171] Thu, 14 June 2012 11:37 Go to previous messageGo to next message
Thanks! Somehow I've never encountered it Smile
Re: Link for CDateTime properties file broken [message #889679 is a reply to message #886175] Tue, 19 June 2012 13:23 Go to previous message
Translation submitted.
Previous Topic:nebula animation classes...are they still supported? Used? Stable?
Next Topic:Analog clock is shown despite CLOCK_DISCRETE being set
Current Time: Tue Feb 20 07:57:12 GMT 2018
Powered by FUDForum. Page generated in 0.01707 seconds
