Home » Eclipse Projects » BIRT » Custom StyleSheet not included when viewed?
Custom StyleSheet not included when viewed? [message #885876] Wed, 13 June 2012 19:20 Go to next message
Ann Black-Ziegelbein is currently offline Ann Black-ZiegelbeinFriend
Hi -
I am new to BIRT and I am creating a sample report to test out. I have included new styles from a custom stylesheet I created and added to the project. i have applied the styles to report elements. However, when I view the report in a web browser (through run -> view report -> web viewer), I don't see my custom style sheet included anywhere when using firebug to debug. I do see that my style is included in the element's class attributes, but it the definition can't be found.
Any thoughts on why the stylesheet does not get included?
Thanks!
Re: Custom StyleSheet not included when viewed? [message #885917 is a reply to message #885876] Wed, 13 June 2012 21:24 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
I assume you set the browser to use for previewing? Any chance you
could write a report off the sample db that has the issue and post it
along with the css?
Jason
On 6/13/2012 3:20 PM, Ann Black-Ziegelbein wrote:
> Hi -
> Thanks!
Previous Topic:Problem with Mysql Stored Procedure
Next Topic:replacing string with parameter
Current Time: Mon Apr 23 13:50:34 GMT 2018
Powered by FUDForum. Page generated in 0.01931 seconds
