referencing models [message #376259] |
Thu, 07 November 2002 06:07 |
Originally posted by: hwill.acm.org
Hi there,
I searched the newsgroup but couldn't find a previous message on this one...
Concretely: I'm playing with EMF/ecore to create an editor for
object-relational mappings. As for the relational part, it's easy enough to
come up with a simple model. For the object part, I'd like to avoid
re-inventing the wheel and rather re-use whatever is already done as part of
the standard ecore model.
My question is: How do I express a reference against the ecore model when
creating my own model, and have the ecore classes excluded from the code
generation via the genmodel? Tried various things, but either end up with
incorrectly generated classes or error messages when going through the emf
wizards.
Any suggestions are welcome.
Hans-Martin
Re: referencing models [message #376261 is a reply to message #376259] |
Thu, 07 November 2002 12:13 |
Ed Merks Messages: 33137 Registered: July 2009 |
Hans-Martin,
We are just finishing off a tutorial that will show how to create models with
dependencies on other models. If you need to reference Ecore, you will need to
the org.eclipse.emf.ecore project to be in your workspace so that the
Ecore.genmodel and Ecore.ecore are available to be referenced by your
Xyz.genmodel and Xyz.ecore.
You may want to have a look in org.eclipse.emf.codegen.ecore and see how the
GenModel.genmodel and GenModel.ecore reference Ecore.
If this doesn't help (and you can't wait for the tutorial ;-) could you explain
what you tried? Or send us a sample of what doesn't work...
Hans-Martin Will wrote:
> Hi there,
> wizards.
> Hans-Martin
Ed Merks
Ed Merks
FUDForum. Page generated in 0.01848 seconds
