Home » Eclipse Projects » Eclipse Platform » MVC pattern Plugin approach
MVC pattern Plugin approach [message #305119] Fri, 23 June 2006 05:52 Go to next message
Originally posted by: dave.dave.com
I have a editor plugin that uses a datastructure and I want to be able to
access that datastructure in another view plugin. How do I access that data
structure in the editor plugin from another plugin ? Can anyone give me an
insight into the plugin interactions. Do I use selectionListener or
something similar ?
Thanks, Dave
Re: MVC pattern Plugin approach [message #305166 is a reply to message #305119] Sun, 25 June 2006 15:16 Go to previous message
Jeffery Caldwell is currently offline Jeffery CaldwellFriend
I would first suggest reading this article:
http://www-128.ibm.com/developerworks/library/os-ecllink/ind ex.html
It demonstrates at least three different approaches to answering your
question of linking the editor and the view. I think it kind of
glosses over the IAdaptable stuff, and when I was first getting into
that was really confusing.
For instance in the rcpnews application the plug-in activator class
registers several of the classes from the data model with the
platform:
public void start(BundleContext context) throws Exception {
super.start(context);
Platform.getAdapterManager().registerAdapters(new
RCPNewsUIAdapterFactory(), IFeedStore.class);
RCPNewsUIAdapterFactory(), IFeed.class);
RCPNewsUIAdapterFactory(), IFeedEntry.class);
Then the RCPNewsUIAdapterFactory class can adapt the model objects as
needed based on what class is asking for an adaptation of your model
class.
On Fri, 23 Jun 2006 15:52:07 +1000, "David" <dave@dave.com> wrote:
>Hi
>something similar ?
>Thanks, Dave
Previous Topic:Redo menu item not displayed in AbstractTextEditor
Next Topic:Text getting lost on the way to Console
Current Time: Thu Jan 18 07:24:30 GMT 2018
Powered by FUDForum. Page generated in 0.01905 seconds
