Home » Eclipse Projects » Eclipse Platform » how to disable NLS warnings in eclipse logs
how to disable NLS warnings in eclipse logs [message #305029] Wed, 21 June 2006 17:02 Go to next message
Originally posted by: gjipp_nospam.ca.ibm.com
I have a project that uses the "old" method of externalizing strings and I am (slowly) converting it across to the new Eclipse NLS
method. Since we have over 10,000 strings there's no way I'll be able to do this all at once.
The problem is, my logs are filling up with: "!MESSAGE NLS unused message:" entries. The messages its complaining are used, just
not by the new NLS (yet).
How to I turn off these log messages?
Gary
Re: how to disable NLS warnings in eclipse logs [message #305205 is a reply to message #305029] Mon, 26 June 2006 11:09 Go to previous message
Dani Megert is currently offline Dani MegertFriend
You cannot. The simplest thing you can do is to have two properties files.
Dani
>Thanks,
>Gary
Previous Topic:No notification of PRE_BUILD for INCREMENTAL_BUILD
Next Topic:how to get IFolder of this plugin?
Current Time: Mon May 21 22:57:21 GMT 2018
Powered by FUDForum. Page generated in 0.01268 seconds
