Home » Eclipse Projects » Eclipse Platform » No notification of PRE_BUILD for INCREMENTAL_BUILD
No notification of PRE_BUILD for INCREMENTAL_BUILD [message #305025] Wed, 21 June 2006 15:54 Go to next message
Originally posted by: matt.querix.com
Hi all,
Eclipse does not seem to fire a PRE_BUILD ResourceChangedEvent before an
INCREMENTAL_BUILD (the type you get if you press the 'Build All'
button). It does this for other types of build, such as AUTO_BUILD or
CLEAN_BUILD, why? This seems like a bug to me.
When the user is building more than one project, I want to clear my
console only at the start of the whole build process and I was inteded
to do this when the PRE_BUILD event is received (doing it in my own
builder would clear the console for each project, which I don't want).
Is there another way to achieve this?
Thanks in advance
Matt D.
Re: No notification of PRE_BUILD for INCREMENTAL_BUILD [message #305026 is a reply to message #305025] Wed, 21 June 2006 16:34 Go to previous messageGo to next message
This behaviour appears to be intentional,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=124490
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101942
However, this does not solve my problem. I need to know when a build is
about to occur, and PRE_BUILD is the only way I can think of.
Does anyone know how else can I solve this problem? I am reluctant to
reopen a bug when the behaviour is described as intentional (though I
may well have to if there not other way of doing it).
Matt D.
Matt Dickie wrote:
> Hi all,
> Thanks in advance
> Matt D.
Re: No notification of PRE_BUILD for INCREMENTAL_BUILD [message #305088 is a reply to message #305026] Thu, 22 June 2006 14:34 Go to previous messageGo to next message
I have created a new bug for this (Eclipse's bugzilla would not allow me
to reopen the old one):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148220
Matt
> Thanks
> Matt D.
> Matt Dickie wrote:
>> Hi all,
>> an INCREMENTAL_BUILD (the type you get if you press the 'Build All'
>> Thanks in advance
>> Matt D.
Re: No notification of PRE_BUILD for INCREMENTAL_BUILD [message #305138 is a reply to message #305088] Fri, 23 June 2006 14:56 Go to previous message
This has been recognised by IBM as a bug and a fix has been released
into the tree for 3.3 milestone 1.
> Matt
>> is about to occur, and PRE_BUILD is the only way I can think of.
>> Thanks
>> Matt D.
>> Matt Dickie wrote:
>>> Hi all,
>>> inteded to do this when the PRE_BUILD event is received (doing it in
>>> my own builder would clear the console for each project, which I
>>> don't want). Is there another way to achieve this?
>>> Thanks in advance
>>> Matt D.
Previous Topic:Probably simple problem with Job and asyncExec()
Next Topic:Using ant from within Eclipse Plugin
Current Time: Wed Jun 20 02:28:53 GMT 2018
Powered by FUDForum. Page generated in 0.02062 seconds
