Home » Eclipse Projects » Eclipse Platform » Plugin Development-Custom Editor Layout
Plugin Development-Custom Editor Layout [message #305003] Wed, 21 June 2006 03:08 Go to next message
Originally posted by: jdobrosi.umd.edu
I'm a student developing an Eclipse plugin to use as a tool when reading
error output from a program written by a fellow student. Essentially, its
a simple debugger that allows one to click on a error message and jump to
the corresponding line of code. However, each error message is in fact
associated to two lines of code in two separate files. Therefore, I want
to be able to, upon clicking an error message, open both files so that
both are viewable at the same time, i.e. have the editor area
automatically split so that one file is on the bottom half of the editor
area, the second on the top half. I know this can be done manually by
clicking and dragging an editor tab in the editor space, but is there a
way to do this automatically in my plugin? I'd appreciate any help or
advice, because I've yet to find anything online that's of any use.
Thanks.
Re: Plugin Development-Custom Editor Layout [message #305015 is a reply to message #305003] Wed, 21 June 2006 10:41 Go to previous message
Camille is currently offline CamilleFriend
John Dobrosielski a ├ęcrit :
> its a simple debugger that allows one to click on a error message and
> jump to the corresponding line of code. However, each error message is
> in fact associated to two lines of code in two separate files.
> Therefore, I want to be able to, upon clicking an error message, open
> both files so that both are viewable at the same time, i.e. have the
> editor area automatically split so that one file is on the bottom half
> of the editor area, the second on the top half. I know this can be done
> manually by clicking and dragging an editor tab in the editor space, but
> is there a way to do this automatically in my plugin? I'd appreciate
> any help or advice, because I've yet to find anything online that's of
> any use. Thanks.
Hi, I think you can look inside the Subversin SVN comparator plugin, it
makes what you are looking for.
Hope it'shelp you.
Bye
Previous Topic:IncrementalBuilder - marking resource built
Next Topic:Flat Border for ExpandableComposite┬┤s client
Current Time: Mon Jan 22 12:35:24 GMT 2018
Powered by FUDForum. Page generated in 0.01568 seconds
