Home » Eclipse Projects » Eclipse Platform » problem with a feature
problem with a feature [message #304991] Tue, 20 June 2006 18:17 Go to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I have 'wrapped' my plugins into a feature. The plugins are working
correctly, but the feature does not appear in the Feature Details list.
However, the feature does appear in the Manage Configuration dialog.
Any ideas what I am doing wrong? Here is my feature.xml (which is in
features/com.crt.tools_0.9.2). It was generated by the feature Export
Wizard.
<feature
id="com.crt.tools"
label="com.crt.tools"
version="0.9.2"
provider-name="%Provider">
<description >
%Description
</description>
<copyright >
%Copyright
</copyright>
<license ">
%License
</license>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.cdt.launch"/>
<import plugin="org.eclipse.cdt.debug.mi.core"/>
<import plugin="org.eclipse.debug.core"/>
<import plugin="org.eclipse.debug.ui"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.cdt.debug.core"/>
<import plugin="org.eclipse.cdt"/>
<import plugin="org.eclipse.cdt.core"/>
<import plugin="org.eclipse.cdt.debug.mi.ui"/>
<import plugin="org.eclipse.cdt.ui"/>
<import plugin="org.eclipse.cdt.debug.ui"/>
<import plugin="org.eclipse.core.variables"/>
<import plugin="org.eclipse.cdt.make.core"/>
<import plugin="org.eclipse.cdt.managedbuilder.core"/>
<import plugin="org.eclipse.cdt.managedbuilder.gnu.ui"/>
<import plugin="org.eclipse.ui.ide"/>
<import plugin="org.eclipse.jface"/>
</requires>
<plugin
id="com.crt.plugin1"
download-size="0"
install-size="0"
version="0.8.2"
unpack="false"/>
<plugin
id="com.crt.plugin2"
download-size="0"
install-size="0"
version="0.8.2"
unpack="false"/>
<plugin
id="com.crt.plugin3"
download-size="0"
install-size="0"
version="1.0.0"/>
<plugin
id="com.crt.plugin4"
download-size="0"
install-size="0"
version="0.9.9"
unpack="false"/>
</feature>
Derek
Re: problem with a feature [message #304993 is a reply to message #304991] Tue, 20 June 2006 19:28 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
Derek Morris <dmsubs@NOSPAM.consertum.com> wrote:
> list. However, the feature does appear in the Manage Configuration
> dialog.
> Wizard.
You need a branding plugin.
http://eclipse.pookzilla.net/2006/01/how-can-i-give-my-eclip se-blob-icon-in.php
Sunil
Re: problem with a feature [message #305013 is a reply to message #304993] Wed, 21 June 2006 09:15 Go to previous messageGo to next message
>> dialog.
>> Wizard.
Sunil,
Thanks - very helpful.
But, this doesn't work if the feature and the branding plugin is
packaged as a .jar or a .zip (which is what the Feature Export Wizard
does). The log file says it "cannot find feature.xml in
<path-to-feature>.jar". I have to supply them both as unpacked directories.
Am I missing something, or is this a known 'feature' of features?
Derek
Re: problem with a feature [message #305034 is a reply to message #305013] Wed, 21 June 2006 17:59 Go to previous message
>>> Hi,
>>> dialog.
>>> Export Wizard.
> Sunil,
> directories.
It works fine for features which are packed in a jar.
That's how I deploy my features/plugins.
I assume that your feature is being installed using the Update wizard.
The Update wizard automatically unpacks the feature jar. The plugins remain
in jarred format.
If you are installing your feature any other way, it must be unpacked when
installed.
Sunil
Previous Topic:How would I generate javadoc using Eclipse from the command line not from the workspace?
Next Topic:How can detect if a perspective is switched to another one
Current Time: Mon Apr 23 12:00:01 GMT 2018
Powered by FUDForum. Page generated in 0.02286 seconds
