Home » Eclipse Projects » Eclipse Platform » menubarPath for "Run As" popup menu?
menubarPath for "Run As" popup menu? [message #304866] Fri, 16 June 2006 14:03 Go to next message
Michael Giroux is currently offline Michael GirouxFriend
I'm trying to contribute a menu to Run As. I've been digging around for
a while now and cannot figure out the correct value for menubarPath
attribute of my <action> element.
What is the correct menubarPath for the Run As popup menu? Alternately,
point me to the plugin that defines it. I've not been able to find that
either.
Michael
Re: menubarPath for "Run As" popup menu? [message #304869 is a reply to message #304866] Fri, 16 June 2006 14:32 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> either.
You can use the Plug-in Registry view to find out who defines what. ex:
I went to org.eclipse.ui/Extension Points/org.eclipse.ui.actionSets.
org.eclipse.debug.ui is a good candidate, and in the second debug.ui
entry I found the Run A&s action.
It's menubar path seems to be org.eclipse.ui.run/runGroup
Later,
PW
Re: menubarPath for "Run As" popup menu? [message #304872 is a reply to message #304869] Fri, 16 June 2006 15:32 Go to previous messageGo to next message
Thanks Paul. This is a good start. Unfortunately, when I launch the
plugin, I'm getting an error that the menubarPath is invalid. From the
help docs, it appears that I need to change this to a symbolic
referecne: additions/runGroup and define "additions". I'll have to
look further to sort this out.
The pointer to the plugin registry was great. Thanks.
Michael
Re: menubarPath for "Run As" popup menu? [message #305105 is a reply to message #304869] Thu, 22 June 2006 20:32 Go to previous message
Paul,
I discovered how to contribute to the Run As menu. My plugin has to
extend org.eclipse.debug.ui.launchShortcuts.
This is described in help:
Platform Plug-in Developer Guide
-> Program debug and launch support
---> Launch shortcuts
http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/guide/debug_launch_uishortcuts.htm
Previous Topic:ViewSorter
Next Topic:plugin for automatic variable/function name replacement
Current Time: Sat Apr 21 12:02:08 GMT 2018
Powered by FUDForum. Page generated in 0.02031 seconds
