Home » Eclipse Projects » Eclipse Platform » selectionChanged and lazy loading
selectionChanged and lazy loading [message #304852] Fri, 16 June 2006 08:16 Go to next message
Michael Pradel is currently offline Michael PradelFriend
I have a IObjectActionDelegate and want to enable/disable the action in
selectionChanged(). It calls a method of my plugin, and I recognized a
strange behaviour when the action is displayed before the plugin has
been used. In this case, selectionChanged() isn't called before the
action is displayed to the user (so that a could disable is), but after
he has clicked on it (which I wanted to avoid).
I know Eclipse uses lazy loading for plugins, but shouldn't the plugin
be loaded in this case?
Is there any other way to disable the action before the plugin is started?
Thanks in advance,
Michael
Re: selectionChanged and lazy loading [message #304855 is a reply to message #304852] Fri, 16 June 2006 11:07 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
What extension point did you use to create this? org.eclipse.ui.popupMenus?
You are right, the lazy loading means that your code will never get
called, until the user clicks on your action at least once (or something
else causes your plugin to load).
But you can add declarative visibility and enablement expressions that
are used before your plugin is loaded. Both objectContributions and
actions can have enablement elements, and I think objectContributions
support visibility elements as well.
Click on the extension point and you can open the extension point
documentation.
Later,
PW
Re: selectionChanged and lazy loading [message #305159 is a reply to message #304855] Sat, 24 June 2006 11:51 Go to previous message
Yes.
Thanks for the hint with <visibility>! The objectContribution is now
hidden if the plugin is not started (using <pluginState>).
Greetings,
Michael
Previous Topic:show views with different ID at the same place
Next Topic:How to update editor after preferences changed !
Current Time: Fri Apr 20 05:16:44 GMT 2018
Powered by FUDForum. Page generated in 0.01634 seconds
