Using POI in Eclipse [message #304657] |
Tue, 13 June 2006 15:22 |
Originally posted by: nateman5069.hotmail.com
I've been tasked with building a data import tool that will pull data from
an excel document and dump it in our oracle database. Unfortunately, I'm
new to Java and Eclipse.
My question is how do you setup POI in Eclipse. I downloaded the
POI-2.5.1-Final release from
http://apache.cs.utah.edu/jakarta/poi/release/bin/ . Then I tried adding
the 3 jar files (poi, poi-contrib, poi-scratchpad) to my Eclipse classpath
that I *think* is Window->Preferences->Ant->Runtime->Add External Jars. I
get a warning about tools.jar not being available and when I try using an
import statement, I do not have access to the org.apache.* packages.
I don't know if I need to recompile the jars first, if I'm in the wrong
classpath, if I need more than just poi, or what. I've been chugging at
this for days with no real headway. I have scoured google and cannot find
any good guides/tutorials for this. If anyone could point me in the right
direction I would greatly appreciate it!
Re: Using POI in Eclipse [message #304661 is a reply to message #304659] |
Tue, 13 June 2006 16:12 |
Danail Nachev Messages: 36 Registered: July 2009 |
Member |
Hi, Nate
The place you found to add this jars is related to the Ant build
scripts. You'll probably won't meet them soon as it seems.
The steps you need start with are, first, create java project. And then
in the properties of this project, there is an entry titled Java Build
Path where you can add the dependencies of your application (project).
Probably you need to get familiar with some common concepts among Java
(like classpath) and how the Eclipse is used.
Sorry, if you are already familiar with this and have something
different in mind. I may misunderstood you, so accept my apologies.
Danail
Jeremy Dowdall wrote:
> is this for a stand-alone application, or RCP / Eclipse plugin?
>> from an excel document and dump it in our oracle database.
>> Unfortunately, I'm new to Java and Eclipse.
>> classpath that I *think* is Window->Preferences->Ant->Runtime->Add
>> External Jars. I get a warning about tools.jar not being available and
>> when I try using an import statement, I do not have access to the
>> find any good guides/tutorials for this. If anyone could point me in
>> the right direction I would greatly appreciate it!
Re: Using POI in Eclipse [message #304662 is a reply to message #304659] |
Tue, 13 June 2006 16:25 |
Stand-alone. I've found that if I add the jar files to the Java Build
path I can at least access the packages and get started.
Re: Using POI in Eclipse [message #304663 is a reply to message #304661] |
Tue, 13 June 2006 16:28 |
Thank you Danail. Yeah I have a lot to learn to say the least. I was
just starting to get frustrated when I've been stumped on this for a few
days.
FUDForum. Page generated in 0.03171 seconds
