Home » Eclipse Projects » Eclipse Platform » NoClassDefFoundError: com/ibm/icu/text/MessageFormat
NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304444] Wed, 07 June 2006 13:03 Go to next message
John O'Shea is currently offline John O'SheaFriend
Member
All,
I'm having a bit of a problem starting up Eclipse 3.2RC6 (see the stack
trace below from the Error Log). I get an error dialog with no details
before the Welcome screen appears and subsequently the Package Explorer
(and several other views) view fails to initialize correctly. The
problem seems to be related to the loading classes from the
com.ibm.icu.text package. For stack trace below, the org.eclipse.jdt.ui
plugin manifest does specify
Import-Package: com.ibm.icu.text
but it does not have a Requires-Bundle entry for "com.ibm.icu".
I've noticed lots of other platform plugins do the same thing (import
the package but don't explicitly add the bundle dependency) so I'm
assuming someone other platform plugin is re-exporting this package but
I can't find which one! Can anyone explain this packaging strategy, and
why it might suddenly fail (assuming I have not touched anything in the
Eclipse distro)?
cheers,
John.
java.lang.NoClassDefFoundError: com/ibm/icu/text/MessageFormat
at org.eclipse.jdt.internal.corext.util.Messages.format(Message s.java:23)
org.eclipse.jdt.internal.ui.filters.FilterDescriptor.createV iewerFilter(FilterDescriptor.java:121)
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.updateBu iltInFilters(CustomFiltersActionGroup.java:510)
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.installF ilters(CustomFiltersActionGroup.java:474)
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(CustomFiltersActionGroup.java:232)
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(CustomFiltersActionGroup.java:212)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup. <init>(PackageExplorerActionGroup.java:128)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. makeActions(PackageExplorerPart.java:917)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. createPartControl(PackageExplorerPart.java:632)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 0)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 5)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1144)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1097)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 11)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:601)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:532)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:562)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:244)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:815)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2429)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:2616)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2597)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:658)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:795)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1437)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 435)
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1399 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1421)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1397)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:708)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304446 is a reply to message #304444] Wed, 07 June 2006 13:33 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
John O'Shea wrote:
> All,
> stack trace below from the Error Log).
Make sure you install it into an empty directory.
Dani
> I get an error dialog with no details before the Welcome screen
> appears and subsequently the Package Explorer (and several other
> views) view fails to initialize correctly. The problem seems to be
> related to the loading classes from the com.ibm.icu.text package. For
> stack trace below, the org.eclipse.jdt.ui plugin manifest does specify
> but I can't find which one! Can anyone explain this packaging
> strategy, and why it might suddenly fail (assuming I have not touched
> anything in the Eclipse distro)?
> cheers,
> John.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304449 is a reply to message #304446] Wed, 07 June 2006 15:01 Go to previous messageGo to next message
Member
Yes, I am installing into a new directory. I've distilled my test case
a little and I've determined that the 'clean' Eclipse 3.2RC6
installation boots up fine until I unzip my feature/plugins in on top of
it. Then it fails at startup with the NoClassDefFound message. (I
clean the configuration and workspace in between each restart to make
sure it isn't carrying over any cached OSGi bundle data)
The odd thing is the zip containing my feature/plugins does not
overwrite or replace any platform plugins. So I'm still thinking
something is going wrong in OSGi classloading layer but it's pretty
difficult to debug.
I'll try a debug launch from another (working) workbench and see if that
shows any more. Does anyone know if there are useful OSGi trace entries
(to put into .options files) that I could enable on the command line
that might help me track down why JDT suddenly looses the ability to
load this ICU class?
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304455 is a reply to message #304449] Wed, 07 June 2006 16:10 Go to previous messageGo to next message
Member
I found an explanation as to why "Import-Package:" is being used at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132749
However, it still isn't clear to me a) how the plugin supplying this
package is found at runtime by the OSGi runtime and b) why this
mechanism stops working when I add my feature/plugins (that do not use
ICU or integrate with JDT UI in any way)...
John.
> difficult to debug.
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304469 is a reply to message #304455] Wed, 07 June 2006 18:53 Go to previous messageGo to next message
Member
--------------080403000108050803080406
I've tracked down the cause of this but I'm not sure if the behavior is
a bug in the OSGi classloader implementation. If someone more familiar
with the equinox implementation could give their opinion it might mean
one less bogus entry in bugzilla.
When debugging this issue I discovered that one of our plugins
internally contains (and exports the packages of) an icu4j v2.8 jar
file. This version of ICU does contain a com.ibm.icu.text package but
not a com.ibm.icu.text.MessageFormat class.
During startup, when the workbench was initializing the JDT Package
Explorer the OSGi classloaders got a bit lost while trying to load the
MessageFormat class. It ended up trying to load the class from our
bundle, rather than from the com.ibm.icu bundle.
See attached stack trace and variable dump (stack_vars.txt) illustrating
that the bundle classloaders
a) have determined that the package (com.ibm.icu.text) is an Imported
Source package.
b) use an 'invalid' PackageSource (SingleSourcePackage) instance to try
subsequently load the class (MessageFormat).
The problem seems to be that the 'BundleLoader#importedSources'
KeyedHashSet for "org.eclipse.jdt.ui_3.2.0.v20060526-0010" plugin has
only an entry, pointing to our bundle.
(For reference, our plugin does declare that it exports the
com.ibm.icu... packages from the jar it contains, but again, I can't
figure out how that bundle ended up in importedsources!)
So the question is , are we wrong to export the com.ibm.icu packages
from our plugin or might this be a bug?
cheers,
John.
> John.
>> case a little and I've determined that the 'clean' Eclipse 3.2RC6
>> of it. Then it fails at startup with the NoClassDefFound message.
>> (I clean the configuration and workspace in between each restart to
>> make sure it isn't carrying over any cached OSGi bundle data)
>> difficult to debug.
>> that shows any more. Does anyone know if there are useful OSGi trace
>> entries (to put into .options files) that I could enable on the
>> command line that might help me track down why JDT suddenly looses the
>> ability to load this ICU class?
name="stack_vars.txt"
Content-Disposition: inline;
filename="stack_vars.txt"
this BundleLoader (id=5529)
bundle BundleHost (id=5564)
classloader DefaultClassLoader (id=5530)
dynamicImportPackages null
dynamicImportPackageStems null
exportedPackages ArrayList (id=5568)
importedSources KeyedHashSet (id=5576)
capacity 1
elementCount 1
elements KeyedElement[7] (id=5586)
[0] null
[1] null
[2] SingleSourcePackage (id=5534)
expid -1
id "com.ibm.icu.text"
supplier BundleLoaderProxy (id=5545)
bundle BundleHost (id=5634)
bundledata BaseData (id=5655)
activator null
adaptor BaseAdaptor (id=5719)
bundleFile DirBundleFile (id=5722)
classpath "textschema.jar,icu4j-2_8.jar,xpp3-1_1_3_2.jar,resource"
dirty false
dynamicImports null
executionEnvironment null
fileName " F:/joshea/ziptest/ant/eclipse/plugins/com.capeclear.textsche ma.runtime_6.6.150.0/ "
id 33
lastModified 1149703866743
location "update@plugins/com.capeclear.textschema.runtime_6.6.150.0/"
manifest CachedManifest (id=5729)
startLevel 4
status 1
storageHooks StorageHook[2] (id=5734)
symbolicName "com.capeclear.textschema.runtime"
type 8
version Version (id=5738)
context BundleContextImpl (id=5658)
domain null
fragments null
framework Framework (id=5662)
manifestLocalization null
proxy BundleLoaderProxy (id=5545)
state 32
statechangeLock Object (id=5665)
stateChanging null
description BundleDescriptionImpl (id=5632)
bundleId 33
containingState SystemState (id=5698)
dependencies ArrayList (id=5702)
dependents ArrayList (id=5703)
equinox_ee -1
host null
lazyData BundleDescriptionImpl$LazyData (id=5704)
lazyDataOffset 150267
lazyDataSize 2068
name "com.capeclear.textschema.runtime"
stateBits 219
userObject BundleLoaderProxy (id=5545)
version Version (id=5708)
loader BundleLoader (id=5639)
classloader DefaultClassLoader (id=5692)
exportedPackages ArrayList (id=5693)
importedSources null
loaderFlags 1
parent BaseAdaptor$ParentClassLoader (id=5578)
policy null
reexportTable null
requiredBundles BundleLoaderProxy[1] (id=5713)
requiredSources KeyedHashSet (id=5714)
pkgSources KeyedHashSet (id=5640)
capacity 7
elementCount 2
elements KeyedElement[14] (id=5667)
[0] null
[1] null
[2] null
[3] null
[4] null
[5] null
[6] null
[7] null
[8] null
[9] SingleSourcePackage (id=5534)
expid -1
[10] null
[11] null
[12] SingleSourcePackage (id=5673)
[13] null
replace false
stale false
[3] null
[4] null
[5] null
[6] null
replace false
loaderFlags 1
policy null
proxy BundleLoaderProxy (id=5563)
reexportTable null
requiredBundles BundleLoaderProxy[25] (id=5581)
requiredSources KeyedHashSet (id=5583)
Thread [main] (Suspended)
org.eclipse.osgi.framework.internal.core.BundleLoader.findIm portedSource(java.lang.String) line: 874
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String, boolean) line: 376
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(java.lang.String) line: 352
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(java.lang.String, boolean) line: 83
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader(jav a.lang.ClassLoader).loadClass(java.lang.String) line: 235
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader(jav a.lang.ClassLoader).loadClassInternal(java.lang.String) line: 302
org.eclipse.jdt.internal.corext.util.Messages.format(java.la ng.String, java.lang.Object) line: 23
org.eclipse.jdt.internal.ui.filters.FilterDescriptor.createV iewerFilter() line: 121
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.updateBu iltInFilters() line: 510
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.installF ilters() line: 474
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(java.lang.String, org.eclipse.jface.viewers.StructuredViewer) line: 232
org.eclipse.jdt.ui.actions.CustomFiltersActionGroup.<init>(org.eclipse.ui.IViewPart, org.eclipse.jface.viewers.StructuredViewer) line: 212
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup. <init> (org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart ) line: 128
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. makeActions() line: 917
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. createPartControl(org.eclipse.swt.widgets.Composite) line: 632
org.eclipse.ui.internal.ViewReference.createPartHelper() line: 332
org.eclipse.ui.internal.ViewReference.createPart() line: 197
org.eclipse.ui.internal.ViewReference(org.eclipse.ui.interna l.WorkbenchPartReference).getPart(boolean) line: 566
org.eclipse.ui.internal.ViewPane(org.eclipse.ui.internal.Par tPane).setVisible(boolean) line: 290
org.eclipse.ui.internal.ViewPane.setVisible(boolean) line: 525
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(boolean) line: 140
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(org.eclipse.ui.presentations.IPresentablePart) line: 268
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(org.eclipse.ui.presentations.IPresentablePart) line: 65
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(org.eclipse.ui.presentations.IPresentableP art) line: 394
org.eclipse.ui.internal.ViewStack(org.eclipse.ui.internal.Pa rtStack).refreshPresentationSelection() line: 1144
org.eclipse.ui.internal.ViewStack(org.eclipse.ui.internal.Pa rtStack).setSelection(org.eclipse.ui.internal.LayoutPart) line: 1097
org.eclipse.ui.internal.ViewStack(org.eclipse.ui.internal.Pa rtStack).showPart(org.eclipse.ui.internal.LayoutPart, java.lang.Object) line: 1311
org.eclipse.ui.internal.ViewStack(org.eclipse.ui.internal.Pa rtStack).createControl(org.eclipse.swt.widgets.Composite, org.eclipse.ui.presentations.StackPresentation) line: 601
org.eclipse.ui.internal.ViewStack(org.eclipse.ui.internal.Pa rtStack).createControl(org.eclipse.swt.widgets.Composite) line: 532
org.eclipse.ui.internal.ViewSashContainer(org.eclipse.ui.int ernal.PartSashContainer).createControl(org.eclipse.swt.widge ts.Composite) line: 562
org.eclipse.ui.internal.PerspectiveHelper.activate(org.eclip se.swt.widgets.Composite) line: 244
org.eclipse.ui.internal.Perspective.onActivate() line: 815
org.eclipse.ui.internal.WorkbenchPage.onActivate() line: 2429
org.eclipse.ui.internal.WorkbenchWindow$6.run() line: 2616
org.eclipse.swt.custom.BusyIndicator.showWhile(org.eclipse.s wt.widgets.Display, java.lang.Runnable) line: 67
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(org.ec lipse.ui.IWorkbenchPage) line: 2597
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(java.la ng.String, org.eclipse.core.runtime.IAdaptable) line: 658
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(ja va.lang.String, org.eclipse.core.runtime.IAdaptable) line: 795
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow() line: 1437
org.eclipse.ui.internal.Workbench.access$10(org.eclipse.ui.i nternal.Workbench) line: 1435
org.eclipse.ui.internal.Workbench$16.run() line: 1399
org.eclipse.ui.internal.Workbench.runStartupWithProgress(int , java.lang.Runnable) line: 1414
org.eclipse.ui.internal.Workbench.openFirstTimeWindow() line: 1397
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow() line: 190
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor(org.eclipse. ui.application.WorkbenchAdvisor).openWindows() line: 708
org.eclipse.ui.internal.Workbench.init() line: 1085
org.eclipse.ui.internal.Workbench.runUI() line: 1847
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org. eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 419
org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse. swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 149
org.eclipse.ui.internal.ide.IDEApplication.run(java.lang.Obj ect) line: 95
org.eclipse.core.internal.runtime.PlatformActivator$1.run(ja va.lang.Object) line: 78
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(java.lang.Object) line: 92
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(java.lang.Object) line: 68
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.Object) line: 400
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[], java.lang.Runnable) line: 177
sun.reflect.NativeMethodAccessorImpl.invoke0(java.lang.refle ct.Method, java.lang.Object, java.lang.Object[]) line: not available [native method]
sun.reflect.NativeMethodAccessorImpl.invoke(java.lang.Object , java.lang.Object[]) line: 39
sun.reflect.DelegatingMethodAccessorImpl.invoke(java.lang.Ob ject, java.lang.Object[]) line: 25
java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) line: 324
org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[], java.net.URL[]) line: 336
org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) line: 280
org.eclipse.core.launcher.Main.run(java.lang.String[]) line: 977
org.eclipse.core.launcher.Main.main(java.lang.String[]) line: 952
--------------080403000108050803080406--
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304488 is a reply to message #304469] Thu, 08 June 2006 11:19 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> Source package.
That's some mighty fine debugging. If I were you, I'd open the bug with
your information. It might be that the system can only handle a package
being exported from one bundle ... although that sounds a little
restrictive. But at least the equinox team will have a look at your
situation.
If you don't need to export the icu stuff from your plugins, I'd remove
the export and move forward.
Later,
PW
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304496 is a reply to message #304488] Thu, 08 June 2006 12:50 Go to previous messageGo to next message
Member
Paul Webster wrote:
<anip>
> situation.
That's what I'm suspecting now too. I've updated our plugins to reuse
the existing com.ibm.icu bundle and filed a bug report -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=145988
John.
Re: NoClassDefFoundError: com/ibm/icu/text/MessageFormat [message #304500 is a reply to message #304496] Thu, 08 June 2006 13:14 Go to previous message
Ah, I see it's to the OSGi spec ... who knew :-)
But there is a way around it for projects that need to restrict their
bundles to lower packages. I hadn't seen any of this. Cool.
Later,
PW
Previous Topic:isGreaterThan of PluginVersionIdentifier
Next Topic:Finding a plug-in installation directory
Current Time: Wed May 23 13:18:35 GMT 2018
Powered by FUDForum. Page generated in 0.01899 seconds
