Home » Eclipse Projects » Eclipse Platform » pde build (product export) out of memory on 3.2RC1
pde build (product export) out of memory on 3.2RC1 [message #302498] Fri, 21 April 2006 15:14 Go to next message
Originally posted by: ecomar_AT_uk_dot_ibm_dot_com.no.spam
In running the export of an eclipse product (an RCP app) using 3.2RC1
and 3.2M6 I encounter an out of memory error that does not occur when
using 3.2M5
any hints ? is it possible to control the heap allocation used by the
pde build ?
Problems during export
Reason:
C:\devel\ws\ap-dev-ws\.metadata\.plugins\org.eclipse.pde.cor e\temp\org.eclipse.pde.container.feature\build.xml:259:
The following error occurred while executing this line:
C:\devel\ws\ap-dev-ws\.metadata\.plugins\org.eclipse.pde.cor e\temp\org.eclipse.pde.container.feature\build.xml:195:
C:\devel\ws\ap-dev-ws\com.ibm.xtools.ras.repository.client.w orkgroup\build.xml:612:
java.lang.OutOfMemoryError: Java heap space
development platform is win32/jdk150,
target eclipse is 3.11/jdk142.
TIA,
Edo
Re: pde build (product export) out of memory on 3.2RC1 [message #302499 is a reply to message #302498] Fri, 21 April 2006 16:17 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
PDE runs the export in the same JRE as Eclipse.
Start Eclipse with more heap space using the correct vm arguments. Something
like:
-Xmx1000M -Xms500M
HTH
Darins
"Edoardo Comar" <ecomar_AT_uk_dot_ibm_dot_com@no.spam> wrote in message
news:e2ass1$5u2$1@utils.eclipse.org...
> using 3.2M5
> pde build ?
> Reason:
ml:612:
> TIA,
> Edo
Re: pde build (product export) out of memory on 3.2RC1 [message #302543 is a reply to message #302499] Mon, 24 April 2006 11:00 Go to previous message
Originally posted by: ecomar.NOSPAM.uk.ibm.com
Thanks Darin it worked !
> like:
> -Xmx1000M -Xms500M
> HTH
> Darins
>> using 3.2M5
>> pde build ?
>> Reason:
> ml:612:
>> TIA,
>> Edo
Previous Topic:Opening a JGroups Channel in Eclipse
Next Topic:Can UI threads be interleaved??
Current Time: Sun May 27 01:41:19 GMT 2018
Powered by FUDForum. Page generated in 0.02116 seconds
