Home » Eclipse Projects » Eclipse Platform » eclipse.ini is the most sensitive, undocumented ini ever? plz help...
eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301459] Fri, 31 March 2006 07:39 Go to next message
No real name is currently offline No real nameFriend
Hi all,
As you can read in the topic, im pretty confused by the way the ini
works...
There are 3 things i need in the ini:
1) -vmargs-Xms256m-Xmx1024m
2) -name eFlex Portfolio Eclipse
3) -vm d:\bea81sp5\jdk142_08\bin\javaw.exe
In the beginning i just put those lines in the ini and expected it to
work, but then we got complaints of people not being able to startup
eclipse because it is using a jdk 1.3.x from the path environment variable.
So I concluded the -vm parameter didnt work and went looking for a
solution.
After waisting hours looking for a solution I discovered that the
eclipse.ini must be the most sensitive ini i have ever encountered...
It seems that you need to split up that parameter in 2 lines like:
-vm
and only then it works...
i found a VERY limited example of this over here:
http://www.eclipse.org/swt/launcher.html
but thats not all, for some it still didnt work
After looking a bit longer i found out that a SPACE behind "-vm" disabled
the parameter too...
so that one i solved myself... but the reason i could solve it, is because
i could test it... if the parameter didnt work eclipse wouldnt start
because it was missing the correct jdk...
but the other 2 parameters i cant even check if they work... so i dont
even know if the syntax for those 2 is correct :(
some people told me to look in the configuration details of the about
window, but if i put the word "crap" inside the ini, "crap" is also shown
in the configuration details... so the configuration details dont tell
anything about parameters working or not...
offcourse ive googled my ass off for finding nice examples or
documentation of the eclipse.ini syntax, but every site sais something
different and none mention something about eclipse.ini being picky about
the syntax...
one site sais it has to be
the other sais
-name
one sais
the other sais
-vmargs -Xms256m -Xmx1024m
and others even say
-vmargs
-Xms256m
-Xmx1024m
which doesnt even work for me
i could imagine it could also be something like
-vmargs
-Xms256m-Xmx1024m
or
-vmargs
Xms256m Xmx1024m
So...
i am hoping at least someone over here know how it should be set up, or
even more important perhaps: how can i check if the parameters work?
and perhaps in the future, the eclipse developers can make their inis
perhaps a bit less sensitive?
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301461 is a reply to message #301459] Fri, 31 March 2006 08:25 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
open a Bugreport on it. This brings the problem to the attention of the
eclipse team.
Maarten Van der Auwera wrote:
> Hi all,
> works...
> solution.
> -vm
> disabled the parameter too...
> because i could test it... if the parameter didnt work eclipse wouldnt
> start because it was missing the correct jdk...
> shown in the configuration details... so the configuration details dont
> tell anything about parameters working or not...
> the syntax...
> one site sais it has to be -name eFlex Portfolio Eclipse
> the other sais
> -name
> one sais -vmargs-Xms256m-Xmx1024m
> the other sais
> and others even say
> -vmargs
> -Xms256m
> -Xmx1024m
> i could imagine it could also be something like -vmargs
> -Xms256m-Xmx1024m
> or
> -vmargs
> Xms256m Xmx1024m
> So...
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301482 is a reply to message #301459] Fri, 31 March 2006 15:41 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
when using these same params from the cmdline:
the vmargs should be the last set of param group - since everything
beyond that switch is shunted off to the jvm. did that cause your problems?
hth,
vijay
> Hi all,
> works...
> variable.
> solution.
> -vm
> dont tell anything about parameters working or not...
> about the syntax...
> the other sais
> -name
> the other sais
> and others even say
> -vmargs
> -Xms256m
> -Xmx1024m
> -Xms256m-Xmx1024m
> or
> -vmargs
> Xms256m Xmx1024m
> So...
> or even more important perhaps: how can i check if the parameters work?
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301745 is a reply to message #301482] Wed, 05 April 2006 08:31 Go to previous messageGo to next message
I just tried placing the "-vmargs-Xms256m-Xmx1024m" parameter at the end
and tried if the ini got a bit less sensitive...
but the -vm parameter still required the path to be on the next line, and
also a space was still enough to freak out eclipse...
for the other parameters: i still do not know how to test them, so i dont
have a clue if they work or not...
is there no one who know how to check if the "-name" and "-vmargs" work??
and please dont tell me to check configuration details cause that lists
even totally random chars out of the eclipse.ini
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301746 is a reply to message #301461] Wed, 05 April 2006 08:36 Go to previous messageGo to next message
it doesnt really seem like a bug to me, but ill report it anyway cause i
dont think it is the way it is supposed to be...
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301748 is a reply to message #301459] Wed, 05 April 2006 08:59 Go to previous messageGo to next message
i just discovered that probabme the reason that
-vmargs
-Xms256m
-Xmx1024m
in the ini didnt work was, once more, because of a space if forgot to
delete behind one of the parameters
-vmargs
-Xms256m-Xmx1024m
still doesnt work though
my best GUESS now then is that the ini should be like this:
-name
-vm
-vmargs
-Xms256m
-Xmx1024m
but this is still a GUESS since no one till now has been able to tell me
how to test if the -name and the -vmargs parameter really work.....
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301753 is a reply to message #301459] Wed, 05 April 2006 10:57 Go to previous messageGo to next message
Guenther Koegel is currently offline Guenther KoegelFriend
Member
Hi Maarten,
Maarten Van der Auwera schrieb:
> Hi all,
> works...
.... text deleted ...
after checking the implementation of the platform launcher (eclipse.exe)
I would like to clarify the format of the ini file:
* one argument per line
* no leading or trailing blanks/tabs
* no empty lines
Why? On Windows it's very common to have blanks in file names and
directories. Only *very* clever programming and a lot of context is
needed to distinguish between parameter and option. It can be done, but
it is awfully complicated...
The solution is now: *one* argument by line, so your ini file looks like
this:
-vmargs
-Xms256m
-Xmx1024m
-name
-vm
and everything is easy to parse :-)
If you want to test it, write a simple Java application and check the
System properties you give in the ini file, e.g.:
.... eclipse arguments, e.g. -clean or -name ...
.... last comes the -vmargs option
-vmargs
-Dtest.property=A text with blanks in it
-Dtest.reason=thats why it must be on one line
Hope that helps.
Bye
Günther
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301763 is a reply to message #301753] Wed, 05 April 2006 13:09 Go to previous messageGo to next message
This helps alot already... Thanks!
But i still have a few smaller questions:
1) i am a bit confused by what you mean by arguments (eg: 1 argument per
line)
Do you mean that BOTH the "parameter" (eg -vm) AND the "value" (eg
d:\bea81sp5\jdk142_08\bin\javaw.exe) are sepperated arguments? cause i
would think that those 2 form ONE argument... But still i think i
understand what your point is (parameters and values both on sepperated
lines)
By this i assume that -vmargs is a parameter and -Xms256m and -Xmx1024m
are values of the -vmargs parameter... right?
2) at the end you say that the vmargs argument comes last, but in your
example you put it first?
-vmargs
-Xms256m
-Xmx1024m
-name
-vm
do you perhaps mean that: when giving the arguments straight to eclipse,
not through the ini, THEN the vmargs argument should come last?
3)I dont really understand how i can test it by checking the system
properties of a simple java app in the ini file? i write things in the ini
file, and i want to test if that works, so by checking the ini file i can
only see what i myself wrote in it? so i dont get your point
Thanks again,
Maarten
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301770 is a reply to message #301763] Wed, 05 April 2006 13:49 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> line)
The file is the coding meaning of argument not the "user program"
meaning of argument. i.e. calling java ex.MyClass -name paul passes in a
String[] args = { "-name", "paul" };
On application option, but 2 arguments.
Later,
PW
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #301774 is a reply to message #301763] Wed, 05 April 2006 14:26 Go to previous messageGo to next message
Member
Hi Maarten,
You are welcome! It's always a pleasure to guide other through ways I
have skinned my knees too. :-)
> line)
Exactly! Remember the method "public static void main(String[] args)"?
Think that each line will be one element in the args array.
> lines)
People have a different understanding of arguments and parameters... So
I introduce a new naming: an option and an option with a value. An
example: The DIR command from Windows.
DIR [file] [options]
DIR A:\myfile.txt /4 /X
The command gets one value "A:\myfile.txt" and two options "/4" and
"/X", a total of 3 arguments.
If you want to distinguish that...
Sorry my fault! The option "-vmargs" separates the Eclipse
options/parameters (e.g. -clean, -name, -nl en_US, -showlocation) from
the JVM options (e.g. -ea -Xmx128M, -Dproperty.name=value). Some options
like "-nl" need a value like "en_US", but the for argument parsing they
are all the same. Have a look in the online documentation for the
Eclipse command line options.
> -vmargs
> -Xms256m
> -Xmx1024m
> -name
Sorry, -name must appear before -vmargs
> -vm
The gory details are much more horrible!
With Eclipse 3.2 the command line arguments are *MERGED* with the
arguments in the ini file. This works fine except for the "-vmargs"
argument which must appear at most only one time, on the command line
XOR in the ini file. You cannot mix!
> ini file, and i want to test if that works, so by checking the ini file
> i can only see what i myself wrote in it? so i dont get your point
Setup:
---------------- ini file ---
-vmargs
-Dtest.property=Hello
---------------- Java -------
public class Main {
System.out.println(System.getProperty("test.property"));
When running this Java application you should see as output the value of
the property "test.property" you gave in the ini file.
Other JVM specific arguments like -Xmx100M are not visible to you
because they change internal settings of the JRE.
A bit clearer now?
Bye
Günther
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302007 is a reply to message #301774] Mon, 10 April 2006 15:03 Go to previous messageGo to next message
Thanks Guenther!
This clarifies alot already...
I havent had the time yet to test those settings out though.
I did just discover i need 2 other parameters included in the eclipse.ini
for some...
-Duser.language=en
-Duser.country=US
So if I am right, this would be correct eclipse.ini?
-name
-vm
-vmargs
-Xms256m
-Xmx1024m
-Duser.language=en
-Duser.country=US
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302009 is a reply to message #302007] Mon, 10 April 2006 15:07 Go to previous messageGo to next message
uh?
where is the edit button??
the layout of my previous post was wrong, and i want to edit it, but i
cant?? why not make a normal vbb/ubb/whatever forum instead of these
unhandy newsgroups?
well anyway, here is what i really wanted to post:
Thanks Guenther!
for some...
-Duser.language=en
-Duser.country=US
-name
-vm
-vmargs
-Xms256m
-Xmx1024m
-Duser.language=en
-Duser.country=US
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302050 is a reply to message #302009] Tue, 11 April 2006 06:03 Go to previous messageGo to next message
Member
Good morning Maarten,
> uh?
> -name
> -vm
> -vmargs
> -Xms256m
> -Xmx1024m
> -Duser.language=en
> -Duser.country=US
Exactly! Watch out for leading or trailing blanks and tabs which may
cause strange error messages or other problems...
Bye
Günther
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302053 is a reply to message #302050] Tue, 11 April 2006 08:57 Go to previous messageGo to next message
Thanks once more!
I just remembered that the -Duser.language=en and -Duser.country=US
parameters are from the borland starteam eclipse plugin. So actually they
arent JVM parameters and they arent Eclipse parameters either.
So am i correct by thinking this:
1) Eclipse parameters allways come first
2) They are followed by JVM parameters (-vmargs indicates the start of JVM
parameters)
3) Then at the end, plugin parameters can be specified
Hope you can confirm or correct this
Maarten
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302054 is a reply to message #302053] Tue, 11 April 2006 09:23 Go to previous messageGo to next message
sorry for all the spam ;)
but i just discovered the following text about the starteam crossplatform
client (so NOT the eclipse plugin, this is a sepperate client prog):
1 Changing StarTeam to English.
1) locate “StarTeamCP.stjava” (by default in C:\Program
Files\Borland\StarTeam Cross-Platform Client 2005 R2)
2) open the file “StarTeamCP.stjava” in a text editor.
2) look for the : "[Java VM]" section
3) then the "options=" line
4) add the VM parameters, like so:
"options=-Xmx256m -Duser.language=en" without the quotes of course.
Now Starteam client will start up in the locale of the machine they are
running on BUT all the menus will be in English
If you were wanting to change the locale the StarTeam client runs in this
can be done in a similar way, by adding "user.region" option:
"options=-Xmx256m -Duser.language=de -Duser.region=GB" without quotes.
If understand this well, then this mean that
-Duser.language=en
-Duser.country=US
are also JVM parameters and not StarTeam plugin parameters.
is this correct?
This means that the position of them is behind the -vmargs parameter (as
you have allready told a few posts ago)?
i am sorry for all uncertainty, but i guess im kinda hard to convince ;)
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302056 is a reply to message #302054] Tue, 11 April 2006 10:17 Go to previous messageGo to next message
Member
Hi Maarten,
> ... text deleted
> crossplatform client (so NOT the eclipse plugin, this is a sepperate
> client prog):
> 1) locate ?StarTeamCP.stjava? (by default in C:\Program
> 2) open the file ?StarTeamCP.stjava? in a text editor.
> this can be done in a similar way, by adding "user.region" option:
> If understand this well, then this mean that -Duser.language=en
> -Duser.country=US
> is this correct?
Hmmm, no, although I might split a very fine hair. :-)
Eclipse uses the option "-nl" plus language encoding to select language
settings, e.g. -nl en_US or -nl de_DE. What you set with -D are system
properties. Who cares is *APPLICATION* dependent! Some properties are
used by the JVM, e.g. user.home or user.name. So you can override your
(short) login name with your full name by specifying
-Duser.name=Maarten Van der Auwera
as an option and Eclipse uses as @author your real name...
Yes. System properties are read/set by the JVM therefore they must
appear after the -vmargs.
Hope that helps.
Bye
Günther
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302059 is a reply to message #302056] Tue, 11 April 2006 11:05 Go to previous messageGo to next message
You have been of great help!
I think I know enough now
Thanks alot!
What i dont understand though is how the eclipse community can still
consider "not fixing" all these strange constraints somehow, even if this
would break with the previous ini's... i dont think you can expect an
average eclipse user to EVER understanding how this kind of ini works...
Even if you would document it somewhere superclearly, it still is waaaaay
too complicated for an ini
Re: eclipse.ini is the most sensitive, undocumented ini ever? plz help... [message #302072 is a reply to message #302059] Tue, 11 April 2006 14:57 Go to previous message
Member
Hi Maarten,
Thanks, it was a pleasure to help you.
If you think so...
[snip]
> this would break with the previous ini's... i dont think you can expect
> an average eclipse user to EVER understanding how this kind of ini
> works... Even if you would document it somewhere superclearly, it still
> is waaaaay too complicated for an ini
Hmmm, sometimes I think they use "Open Source" as an excuse not to
document anything, because they offer the "Source code". I had to do a
lot of reverse engineering in order solve some of my problems. It's
quite frustrating and time wasting to work that way.
In your case somebody else solved your problem before *and* shared their
knowledge and experience with you, thats how usenet still thrives...
Sometimes your not so lucky!
Bye
Günther
Previous Topic:eclipse automatically exit
Next Topic:Jobs: Avoid Cancel / Wait for jobs on workbench shutdown
Current Time: Thu Apr 26 19:15:39 GMT 2018
Powered by FUDForum. Page generated in 0.04187 seconds
