Home » Eclipse Projects » Eclipse Platform » creating icons defined in a different plugin
creating icons defined in a different plugin [message #299753] Thu, 23 February 2006 18:29 Go to next message
Rashmy A is currently offline Rashmy AFriend
Could you please let me know how Plugin-A can create an image using the icon
path from Plugin-B?
The icons are defined in the plugin.xml file in my extension point. I
decided to get hold of the pluginid from the extension and use the plugin to
get the image descriptor. But the methods that used to fetch the plugin
given a pluginid seems to be deprecated in 3.0. Are there other methods that
I could use to fetch the plugin given the plugin id?
Rashmy
Re: creating icons defined in a different plugin [message #299754 is a reply to message #299753] Thu, 23 February 2006 18:49 Go to previous message
Rashmy,
Platform.getBundle should do the trick.
Rashmy wrote:
> path from Plugin-B?
> Rashmy
Previous Topic:Line numbers are not updated in text editor
Next Topic:how to print a stack trace in an ExceptionDialog?
Current Time: Thu May 24 05:43:56 GMT 2018
Powered by FUDForum. Page generated in 0.01947 seconds
