Home » Eclipse Projects » Eclipse Platform » ESRI ArcGIS Java Engine and Eclipse RCP
ESRI ArcGIS Java Engine and Eclipse RCP [message #299511] Mon, 20 February 2006 05:18 Go to next message
Originally posted by: innoware.gmail.com
I was wondering if anyone here has tried using ESRI ArcGIS Java Engine
together with Eclipse to develope applications?
I will be starting on a GIS project using these tools and are wondering if
there are any sample codes or information to get me started. Furthermore,
are there any particular things that I should pay close attention to?
Lastly, what are your general experiences with using these tools together
to create and deploy applications?
BT
Re: ESRI ArcGIS Java Engine and Eclipse RCP [message #299642 is a reply to message #299511] Tue, 21 February 2006 15:45 Go to previous message
Originally posted by: scott.m.weigner.mdnt.com
"BT" <innoware@gmail.com> wrote in message
news:f64cf3bdfbed48b2be3591f1368c9dce$1@www.eclipse.org...
> BT
We are just starting some development with it. With the little prototyping
we have done, the only problem we have seen is that sometimes the window
resizing does not work right. When you let go of the mouse button, sometimes
the map is just all white with some small text instead of the normal map. It
may be a video driver problem because it does not do it on some machines and
other machines the problem is there but does not do it as often.
Scott
Previous Topic:Problems with <visibility>
Next Topic:Problems with Eclipse 3.2 (x64)
Current Time: Wed Apr 25 20:28:13 GMT 2018
Powered by FUDForum. Page generated in 0.01847 seconds
