Can not launch Eclipse in RH Enterprise 3 [message #299331] |
Tue, 14 February 2006 18:49 |
Originally posted by: brad12s.yahoo.com
Oh man, i have not been able to get to a resolution on this. I hope you
can help. After a recent update to RedHat enterprise 3 i am unable to
launch Eclipse. Eclipse will start to initialize, show the splash screen
and then prompt for a workspace. When i select 'any' location on my linux
box for a workspace, eclispe displays the error box that says "Workspace
in use, choose a different one." I have read sevearl post regarding
similar problems. There is the .lock file in the .../workspace/.metadata/
directory. I have removed all .lock files and even my entire workspace
directory for that matter. I have also removed the ~.metadata directory
and i stil recieve the prompt to select a workspace.
Now from most post i have read I have undestood that this problem can do
with lauching multiple instances of Eclipse at the same time. Here is the
commmand i am using to launch Eclipse with:
eclipse -vm /home/brad/Java/jre1.5.0_06/bin/java
When Eclipse is prompting for a workspace i ran a "ps -ef" on another
terminal and it show many Eclipse threads, this seems like it might be
useful in determining a resolution:
brad 15277 3788 0 18:27 pts/1 00:00:00
brad 15278 15277 0 18:27 pts/1 00:00:01
~/Java/jre1.5.0_06/bin/java -jar eclipse
brad 15279 15278 0 18:27 pts/1 00:00:00
/home/brad/Java/jre1.5.0_06/bin/java -jar eclipse
brad 15280 15279 0 18:27 pts/1 00:00:00
brad 15281 15279 0 18:27 pts/1 00:00:00
brad 15282 15279 0 18:27 pts/1 00:00:00
brad 15283 15279 0 18:27 pts/1 00:00:00
brad 15284 15279 0 18:27 pts/1 00:00:00
brad 15285 15279 0 18:27 pts/1 00:00:00
brad 15286 15279 0 18:27 pts/1 00:00:00
brad 15287 15279 0 18:27 pts/1 00:00:00
brad 15288 15279 0 18:27 pts/1 00:00:00
brad 15289 15279 0 18:27 pts/1 00:00:00
brad 15290 15279 0 18:27 pts/1 00:00:00
brad 15294 15279 0 18:27 pts/1 00:00:00
brad 15295 15279 0 18:27 pts/1 00:00:00
brad 15296 15279 0 18:27 pts/1 00:00:00
any help is appreciated! thanks in advance! Brad
Re: Can not launch Eclipse in RH Enterprise 3 [message #299769 is a reply to message #299331] |
Thu, 23 February 2006 20:07 |
These are very weird. I don't normally see this. Do you have Eclipse from
our download site, or from Red Hat? If it's the Red Hat RPM you have
installed, then you should contact them.
You can try adding the following to the command-line:
-vmargs -Dosgi.locking=none
cheers,
d.
FUDForum. Page generated in 0.03116 seconds
