Home » Eclipse Projects » Eclipse Platform » Line Numbers when Printing
Line Numbers when Printing [message #295879] Fri, 09 December 2005 11:04 Go to next message
Eclipse User
Originally posted by: anthony.santinello.experian.com
Is there any way when I print a file to the printer, I can also have it
display the line numbers?
Re: Line Numbers when Printing [message #295913 is a reply to message #295879] Mon, 12 December 2005 05:07 Go to previous messageGo to next message
Eclipse User
Originally posted by: automatic.javalobby.org
Not directly in Eclipse, no. However, other utilities such as 'a2ps' allow you to put page numbers on (PostScript) printer files, which you can then transform to PDF with ps2pdf or pspdf (or print directly if you have a PostScript compatible printer).
a2ps --line-numbers=5 Test.java --output=- | ps2pdf - Test.pdf
If you're running Windows, both of these are available in Cygwin under the package names 'a2ps' and 'ghostscript' respectively.
Re: Line Numbers when Printing [message #295914 is a reply to message #295879] Mon, 12 December 2005 05:11 Go to previous messageGo to next message
Eclipse User
Originally posted by: vlad_dumitrescu.hotmail.com
"Tony" <anthony.santinello@experian.com> wrote in message
news:6e0e05921fb6035c4418909b411dae3d$1@www.eclipse.org...
Not yet. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=19602
regards,
/Vlad
Re: Line Numbers when Printing [message #296090 is a reply to message #295879] Wed, 14 December 2005 19:58 Go to previous message
Eclipse User
Originally posted by: varavamu.yahoo.com
You can also use the java2html plugin - one of the options is to print
line numbers in the generated html file. As an added bonus, if you are
printing to a color printer - you also get syntax coloring. Once you get
this html file - you can open it in any browser and print from there!
hth,
Vijay
> it display the line numbers?
Previous Topic:"Gdk-CRITICAL" Error message
Next Topic:How to define groups in a preference page?
Current Time: Sat May 18 06:00:50 EDT 2013
Powered by FUDForum. Page generated in 0.01855 seconds
