Home » Modeling » TMF (Xtext) » [Xtext] Model elements extra initialization
Re: [Xtext] Model elements extra initialization [message #29585 is a reply to message #29530] |
Wed, 18 February 2009 11:22 |
Lazar Codrut-Lucian Messages: 91 Registered: July 2009 |
Member |
I am using UML as a metamodel:
---mydsl.xtxt---
preventMMGeneration
importMetamodel "http://www.eclipse.org/uml2/2.1.0/UML" as uml;
I want to be able to change some attributes at initialization.
For instance, I have several rules for uml::Operation, one being:
ValidateOperationRule[uml::Operation]:
"validate" name=ID
I want to be able to set some properties in the uml::Operation to the
default values I need for a "ValidateOperation".
Also, I need to apply a stereotype to this uml::Operation.
What are the recommended steps needed for importing the UML profile and
applying the stereotypes?
Thank you,
Lucian
Sebastian Zarnekow wrote:
> Hi Lucian,
> sorry if I miss the point, but I think you'ld like to build a textual
> DSL on top of an existing UML metamodel? So you should be able to import
> your metamodel in your grammar and initialize instances and attributes
> via parser rules. This should be pretty straightforward. If you want to
> set some additional values (defaults, mandatory attributes in your
> metamodel that you do not want to represent in your textual syntax) you
> can use the linking hook in your resource.
> Please have a look at org.eclipse.xtext.crossref.internal.Linker.
> Although it is currently in an internal package, you should be able to
> create your own implementation that extends the default Linker (I'll
> file a bugzilla to move this useful baseclass to crossref.impl). The
> implementation provides several hooks to set (and unset) default values
> etc. See XtextLinker for extensive usage of the different template methods.
> Most likely we'll come up with another service interface that makes it
> more straighforward to enhance the model before and after the linker did
> his job.
> If my guess was wrong and you want to achieve something else please
> elaborate a bit more on it :-)
> Sebastian
>> I want to make a DSL that maps to UML elements.
>> I need to apply stereotypes and initialize certain attributes of the UML
>> elements I use.
>> Can this be done? What is the proper place to do this initialization?
>> Thank you,
>> Lucian
Re: [Xtext] Model elements extra initialization [message #30146 is a reply to message #29585] |
Wed, 18 February 2009 13:12 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Lucian,
the grammar should look like this snippet:
language my.namespace.UmlLanguage
import "http://www.eclipse.org/uml2/2.1.0/UML" as uml
ValidateOperationRule returns uml::Operation:
"validate" name=ID;
Pretty much the same as you suggested.
However, to initialize any default value, you have to subclass
org.eclipse.xtext.crossref.internal.Linker and override
* Linker.setDefaultValueImpl(EObject obj, EReference ref,
IDiagnosticProducer producer), and
* Linker.beforeEnsureIsLinked(EObject obj, EReference ref,
The latter is called before the linker made any attempt do establish a
crossreference for the given obj and feature. The first is a well
defined hook to initialize any default values for references. If you
want to init some EAttributes, I advise to use the more coarse-grained
method
* Linker.ensureLinked(EObject obj, IDiagnosticProducer producer).
For your short example, the code might look like similar to the following:
public class UMLLinker extends Linker {
@Inject
private UMLLanguageGrammarAccess grammarAccess;
public void ensureLinked(EObject obj, IDiagnosticProducer producer) {
super.ensureLinked(obj, producer);
if (obj instanceof Operation &&
isValidateOperationRule(
NodeUtil.getNodeAdapter(obj).getGrammarElement()) {
Operation op = obj;
// set default attributes
boolean isValidateOperationRule(EObject grammarElement) {
return grammarAccess.prValidateOperationRule().getRule() ==
grammarElement || // might even be a RuleCall with call.getRule() == ..
protected void setDefaultValueImpl(EObject obj, EReference ref,
if (ref == <OperationStereoptype>) {
obj.setStereotype(createStereotype(..));
Don't forget to register your Linker with bindILinker() in your runtime
module.
The pseudo code is only a shot in the dark, but the pointer to existing
methods may help you to init your model as you like.
Sebastian
Lazar Codrut-Lucian schrieb:
> Hello,
> ---mydsl.xtxt---
> preventMMGeneration
> "validate" name=ID
> Thank you,
> Lucian
>> Hi Lucian,
>> his job.
>> Regards,
>> Sebastian
>>> elements I use.
>>> Thank you,
>>> Lucian
Re: [Xtext] Model elements extra initialization [message #30463 is a reply to message #29585] |
Thu, 19 February 2009 08:59 |
Hi Lucian,
I didn't get that your are refering to and still using
openArchitectureWare Xtext. So my answer won't help you...
Please post your oAW related questions in the forum at
www.openarchitectureware.org.
Sebastian
> Hello,
> ---mydsl.xtxt---
> preventMMGeneration
> "validate" name=ID
> Thank you,
> Lucian
>> Hi Lucian,
>> his job.
>> Regards,
>> Sebastian
>>> elements I use.
>>> Thank you,
>>> Lucian
Re: [Xtext] Model elements extra initialization [message #30601 is a reply to message #30463] |
Fri, 20 February 2009 14:42 |
Member |
I did not know I was using the other Xtext.
I'll try to install TMF Xtext and then I will try your suggestions here.
Lucian
> Hi Lucian,
> Sebastian
>> Hello,
>> ---mydsl.xtxt---
>> preventMMGeneration
>> "validate" name=ID
>> Thank you,
>> Lucian
>>> Hi Lucian,
>>> methods.
>>> his job.
>>> Regards,
>>> Sebastian
>>>> UML
>>>> elements I use.
>>>> Thank you,
>>>> Lucian
Current Time: Thu Apr 25 21:33:09 GMT 2024
Powered by FUDForum. Page generated in 0.02566 seconds
