Home » Eclipse Projects » Eclipse Platform » How do I change JRE javaw path in Eclipse 3.0?
How do I change JRE javaw path in Eclipse 3.0? [message #287693] Wed, 06 July 2005 15:39 Go to next message
Originally posted by: falcom.globaltrak.com.my
To eclipse users:
How do i change JRE javaw.exe path in Eclipse 3.0?
Eclipse auto configure the JRE javaw.exe path, which I would like to
change.
Regards & thanks,
Chin Hoong
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287700 is a reply to message #287693] Wed, 06 July 2005 16:13 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Are you saying you want to java.exe instead of javaw.exe or are you
saying you want to use a different JRE entirely from the default?
If you are saying you want to switch to use java.exe, then on the Java
Application Launch Configuration of interest, switch to the "JRE" page,
select "Alternate JRE", select the JRE of interest, and then in the
group just below that select "Alternate" radio button and put in java
instead.
If you are saying you want to switch to a different JRE entirely, then
go to Windows->Preferences->Java->Installed JRE's, and use the "ADD"
button to add a new jre. You can then make it the default for the
workspace there.
ChinHoong wrote:
> To eclipse users:
> change.
> Regards & thanks,
> Chin Hoong
Rich Kulp
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287797 is a reply to message #287700] Thu, 07 July 2005 03:46 Go to previous messageGo to next message
Hi Rich,
I am using Eclipse 3.0 and Windows XP.
Click on Eclipse Help/ About Eclipse platform/ Configuration Details/
I can see my Java VM path is "eclipse.vm=C:\WINDOWS\system32\javaw.exe"
How can I change this path to other directory?
Thanks!
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dagvv5$sda$1@news.eclipse.org...
> Are you saying you want to java.exe instead of javaw.exe or are you saying
> select "Alternate JRE", select the JRE of interest, and then in the group
> just below that select "Alternate" radio button and put in java instead.
> If you are saying you want to switch to a different JRE entirely, then go
> to Windows->Preferences->Java->Installed JRE's, and use the "ADD" button
> to add a new jre. You can then make it the default for the workspace
> there.
> ChinHoong wrote:
>> To eclipse users:
>> change.
>> Regards & thanks,
>> Chin Hoong
> Rich Kulp
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287847 is a reply to message #287797] Thu, 07 July 2005 14:31 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
ECOS learner wrote:
> Hi Rich,
You can specify a JVM to use on the command-line to eclipse.exe. See
http://eclipsewiki.editme.com/StartupProblems for details on how to do it.
HTH,
Eric
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287862 is a reply to message #287847] Thu, 07 July 2005 15:38 Go to previous messageGo to next message
Oh, I thought you meant to compile code against and run applications,
not the JRE that you want to run Eclipse itself with. Sorry. :-)
> HTH,
> Eric
Rich Kulp
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287913 is a reply to message #287847] Fri, 08 July 2005 04:12 Go to previous messageGo to next message
Hi Eric:
For the command line eclipse.exe -vm c:\....
1) You need to type in the command line-vm everytime you start up eclipse,
is there a permanet way?
2) Eclipse 3.0 is in GUI. Is there any GUI way, instead of command line?
"Eric Rizzo" <eclipse3@rizzoweb.com> wrote in message
news:dajedm$koq$1@news.eclipse.org...
> ECOS learner wrote:
>> Hi Rich,
> HTH,
> Eric
Re: How do I change JRE javaw path in Eclipse 3.0? [message #287927 is a reply to message #287913] Fri, 08 July 2005 13:40 Go to previous message
If you are in Windows you create a desktop shortcut, or menu item to do it.
Rich Kulp
Previous Topic:How to get tree item from item name?
Next Topic:Eclipse 3.1RC2 ${eclipse.home} not working?
Current Time: Sun Feb 18 05:22:35 GMT 2018
Powered by FUDForum. Page generated in 0.02314 seconds
