Home » Eclipse Projects » Eclipse Platform » SWT_AWT Linux-GTK crash ?
SWT_AWT Linux-GTK crash ? [message #286855] Mon, 20 June 2005 12:26 Go to next message
DC is currently offline DCFriend
I am facing a problem where I have embedded a SWING JTable in a JPanel in a
Frame inside a SWT Composite as suggested in
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet154.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
In fact, I have put this into a view inside Eclipse workbench.
I am using SWT-GTK on Linux, with Sun Java 1.5 and I am using X Display
manager on windows to access it.
I am getting these crash messages quite frequentely:
The program '<unknown>' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadWindow (invalid Window parameter)'.
(Details: serial 838 error_code 3 request_code 15 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
What could be causing this to occur ?
DC
Re: SWT_AWT Linux-GTK crash ? [message #286867 is a reply to message #286855] Mon, 20 June 2005 19:39 Go to previous messageGo to next message
Originally posted by: steve_northover.ca.ibm.com
Are you seeing this (possible bug in AWT)?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74095
"DC" <mahesh.dc@philips.com> wrote in message
news:d96clj$4st$1@news.eclipse.org...
a
function.)
> DC
Re: SWT_AWT Linux-GTK crash ? [message #286887 is a reply to message #286867] Tue, 21 June 2005 05:13 Go to previous messageGo to next message
Originally posted by: nospam.nospam.net
Yeah, I am facing the same problem ... ?
Besides that, I get these errors at times:
java.lang.StackOverflowError
at sun.awt.X11.XlibWrapper.CallErrorHandler(Native Method)
at sun.awt.X11.XToolkit.SAVED_ERROR_HANDLER(XToolkit.java:131)
at sun.awt.X11.XToolkit$1.handleError(XToolkit.java:159)
at sun.awt.X11.XToolkit.GlobalErrorHandler(XToolkit.java:140)
Is there a solution for it ?
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:d97629$761$1@news.eclipse.org...
>> in
> a
> function.)
>> Thanks,
>> DC
Re: SWT_AWT Linux-GTK crash ? [message #286933 is a reply to message #286887] Tue, 21 June 2005 20:33 Go to previous message
I'm not sure it's the same problem but let's continue the discussion in the
bug report anyways.
"DC" <nospam@nospam.net> wrote in message
news:d987m4$5la$1@news.eclipse.org...
> >> Hi,
> >> in
> > a
> > function.)
> >> Thanks,
> >> DC
Previous Topic:Problem importing projects in 3.1RC2 / RC3
Next Topic:trouble with a JSP directive
Current Time: Mon May 21 08:44:54 GMT 2018
Powered by FUDForum. Page generated in 0.02133 seconds
