Re: eclipse 3.1M7 startup on linux [message #285302 is a reply to message #285295] |
Sat, 14 May 2005 18:59   |
Originally posted by: pascal.ibm.canada
Make sure that the archive is not corrupted.
PaScaL
snpe wrote:
> Hello,
> I build eclipse cvs on linux (build I20050513-1415 - M7)
> I get next error :
> debug output and log error :
> Start VM: /u1/j2sdk1.4.2/bin/java
> -Xms40m
> -Xmx256m
> -jar /u2/buildScripts/result/eclipse/startup.jar
> -os linux
> -ws gtk
> -arch x86
> -launcher /u2/buildScripts/result/eclipse/eclipse
> -name Eclipse
> -showsplash 600
> -exitdata 334801a
> -debug
> -vm /u1/j2sdk1.4.2/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> Install location:
> file:/u2/buildScripts/result/eclipse/
> Configuration file:
> file:/u2/buildScripts/result/eclipse/configuration/config.in i loaded
> Configuration location:
> Framework located:
> file:/u2/buildScripts/result/eclipse/plugins/org.eclipse.osg i_3.1.0.jar
> File
> jar:file:/u2/buildScripts/result/eclipse/plugins/org.eclipse .osgi_3.1.0.jar!/eclipse.properties
> not found.
> Framework classpath:
> Splash location:
> /u2/buildScripts/result/eclipse/plugins/org.eclipse.platform _3.1.0/splash.bmp
> runCommand:
> </u2/buildScripts/result/eclipse/eclipse><-name><Eclipse><-showsplash ><600>< /u2/buildScripts/result/eclipse/plugins/org.eclipse.platform _3.1.0/splash.bmp >
> Debug options:
> file:/u2/buildScripts/result/eclipse/.options not found
> Time to load bundles: 40
> Starting application: 1913
> runCommand:
> </u2/buildScripts/result/eclipse/eclipse><-name><Eclipse><-exitdata ><334801a><An
> error has occurred. See the logfile
> /u2/buildScripts/result/eclipse/configuration/1116066358151. log. >
> log error
> !SESSION 2005-05-14 12:25:57.796
> eclipse.buildId=I20050513-1415
> java.version=1.4.2
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> Command-line arguments: -os linux -ws gtk -arch x86 -debug
> !ENTRY org.eclipse.osgi 2005-05-14 12:25:59.979
> !MESSAGE An error occured while automatically activating bundle
> org.eclipse.ui.workbench (83).
> !STACK 0
> org.osgi.framework.BundleException: The activator
> org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench
> is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:266)
> at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:112)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
> at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
> at
> org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:74)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
> at java.lang.ClassLoader.defineClass0(Native Method)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
> at
> org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:322)
> at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
> at
> org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:305)
> at
> org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:197)
> at
> org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:179)
> at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:137)
> at
> org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:78)
> at
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1259)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:371)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
> at org.eclipse.core.launcher.Main.run(Main.java:977)
> at org.eclipse.core.launcher.Main.main(Main.java:952)
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
> at java.lang.Class.getDeclaredConstructors0(Native Method)
> at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
> at java.lang.Class.getConstructor0(Class.java:1922)
> at java.lang.Class.newInstance0(Class.java:278)
> at java.lang.Class.newInstance(Class.java:261)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
> ... 55 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.osgi 2005-05-14 12:25:59.989
> org.eclipse.ui.ide (75).
> !STACK 0
> org.eclipse.ui.internal.ide.IDEWorkbenchPlugin for bundle
> org.eclipse.ui.ide is invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org/eclipse/ui/plugin/AbstractUIPlugin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 27 more
> Root exception:
> java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.osgi 2005-05-14 12:26:00.114
> !MESSAGE Application error
> !STACK 1
> org.eclipse.core.runtime.CoreException[1]: java.lang.ClassNotFoundException:
> org.eclipse.ui.internal.ide.IDEApplication
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:403)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.02032 seconds
