Home » Eclipse Projects » Babel » Non-translatable Strings and properties files in fragment
Non-translatable Strings and properties files in fragment [message #28207] Wed, 13 May 2009 02:54 Go to next message
Kentarou Fukuda is currently offline Kentarou FukudaFriend
Member
Hi Babel team,
I'm now working for PTT, and I found 2 issues below. Would you please help
us to solve these issues?
1. Non-translatable Strings
We followed the guidelines below to exclude Non-translatable Strings.
http://wiki.eclipse.org/Eclipse_Globalization_Guidelines#Non -translatable_Message_Strings
However, some Strings between
"# START NON-TRANSLATABLE" and "# END NON-TRANSLATABLE"
are included in Pseudo translation.
Is it OK? If it means that these Strings are handled as translatable
Strings,
would you please check our properties file and let me know how to fix it?
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.actf/or g.eclipse.actf.common/plugins/org.eclipse.actf.model.dom.htm l/src/org/eclipse/actf/model/internal/dom/html/parser/public _entities.properties?root=Technology_Project&view=co
2. Properties files in Fragment
I found that properties files in Fragment are not included in Pseudo
translation.
Is there any way to include properties files in Fragment into translation
target?
We have 3 fragment.properties files in our project.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.actf/or g.eclipse.actf.visualization/plugins/org.eclipse.actf.visual ization.blind.html/fragment.properties?root=Technology_Proje ct&view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.actf/or g.eclipse.actf.visualization/plugins/org.eclipse.actf.visual ization.blind.odfbyhtml/fragmentodf.properties?root=Technolo gy_Project&view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.actf/or g.eclipse.actf.visualization/plugins/org.eclipse.actf.visual ization.flash/fragment.properties?root=Technology_Project&am p;view=co
Thank you in advance for your support.
Kentarou
Kentarou
Re: Non-translatable Strings and properties files in fragment [message #28284 is a reply to message #28207] Wed, 13 May 2009 17:31 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Can you please file a bug against Babel Server for #1? I wasn't even
aware that we had to support that :)
As for #2, I believe Kit (our fearless leader) can answer that. Kit?
Thanks!
Kentarou Fukuda wrote:
> Hi Babel team,
> help us to solve these issues?
> However, some Strings between "# START NON-TRANSLATABLE" and "# END
> NON-TRANSLATABLE"
> Strings,
> translation.
> translation target?
> Best regards,
> Kentarou
Re: Non-translatable Strings and properties files in fragment [message #28322 is a reply to message #28284] Wed, 13 May 2009 17:36 Go to previous messageGo to next message
Eclipse Webmaster (Denis Roy) wrote:
As a follow-up, I just noticed that the Guidelines document is a working
draft, so I believe none of those guidelines have been formally accepted
.... yet.
Denis
> Thanks!
>> Hi Babel team,
>> NON-TRANSLATABLE"
>> Strings,
>> translation.
>> translation target?
>> Best regards,
>> Kentarou
Re: Non-translatable Strings and properties files in fragment [message #28435 is a reply to message #28322] Tue, 19 May 2009 05:10 Go to previous messageGo to next message
Member
Hi Denis,
Thank you for your reply.
I submitted the bug for #1 (for future enhancement).
Shall I need to submit a bug for #2?
#2:
>>> translation target?
Kentarou
> .... yet.
> Denis
>> Thanks!
>>> Hi Babel team,
>>> NON-TRANSLATABLE"
>>> Strings,
>>> translation.
>>> translation target?
>>> Best regards,
>>> Kentarou
Kentarou
Re: Non-translatable Strings and properties files in fragment [message #28901 is a reply to message #28435] Wed, 20 May 2009 02:59 Go to previous messageGo to next message
Kit Lo is currently offline Kit LoFriend
As far as I know, we cannot create a fragment for a fragment. Have you
seen that done somewhere? If you can provide an example, I will
investigate. Otherwise, the answer is that we do not support creating a
Re: Non-translatable Strings and properties files in fragment [message #28938 is a reply to message #28901] Wed, 20 May 2009 13:52 Go to previous message
Member
Hi Kit,
I forgot that translations are provided as a fragment...
I'll move properties files into the parent plugin or somewhere in next
release.
Kentarou
Kentarou
Re: Non-translatable Strings and properties files in fragment [message #578741 is a reply to message #28207] Wed, 13 May 2009 17:31 Go to previous message
Thanks!
> Hi Babel team,
> NON-TRANSLATABLE"
> Strings,
> translation.
> translation target?
> Best regards,
> Kentarou
Re: Non-translatable Strings and properties files in fragment [message #578754 is a reply to message #28284] Wed, 13 May 2009 17:36 Go to previous message
.... yet.
Denis
> Thanks!
>> Hi Babel team,
>> NON-TRANSLATABLE"
>> Strings,
>> translation.
>> translation target?
>> Best regards,
>> Kentarou
Re: Non-translatable Strings and properties files in fragment [message #578802 is a reply to message #28322] Tue, 19 May 2009 05:10 Go to previous message
Member
Hi Denis,
#2:
>>> translation target?
Kentarou
> .... yet.
> Denis
>> Thanks!
>>> Hi Babel team,
>>> NON-TRANSLATABLE"
>>> Strings,
>>> translation.
>>> translation target?
>>> Best regards,
>>> Kentarou
Kentarou
Re: Non-translatable Strings and properties files in fragment [message #578833 is a reply to message #28435] Wed, 20 May 2009 02:59 Go to previous message
Re: Non-translatable Strings and properties files in fragment [message #578843 is a reply to message #28901] Wed, 20 May 2009 13:52 Go to previous message
Member
Hi Kit,
release.
Kentarou
Kentarou
Previous Topic:Getting Galileo langpacks to work without p2 metadata
Next Topic:Getting Galileo langpacks to work without p2 metadata
Current Time: Thu Feb 22 21:22:49 GMT 2018
Powered by FUDForum. Page generated in 0.02699 seconds
