Home » Eclipse Projects » Babel » No version for MAT project in translation tool
No version for MAT project in translation tool [message #28052] Wed, 06 May 2009 12:57 Go to next message
Elena Nayashkova is currently offline Elena NayashkovaFriend
when the map file for MAT project was added, the drop down list for the
version offered only "unspecified". I think it might cause the problem in
the translation tool - "Strings in File" and "Translation For Key"
sections remain empty, i.e. it's not possible to add a translation.
What shall we do to add a version of MAT? Will it solve the issue or is
there something else we do wrong?
Elena.
Re: No version for MAT project in translation tool [message #28168 is a reply to message #28052] Sat, 09 May 2009 09:42 Go to previous message
Originally posted by: atoulme.intalio.com
Elena, you need to define versions in the bugzilla management tools
exposed from the committer tools of the Eclipse portal.
If you don't have access, someone in your project or from the PMC should.
Antoine
Elena Nayashkova wrote:
> in the translation tool - "Strings in File" and "Translation For Key"
> sections remain empty, i.e. it's not possible to add a translation. What
> shall we do to add a version of MAT? Will it solve the issue or is there
> Elena.
Re: No version for MAT project in translation tool [message #578700 is a reply to message #28052] Sat, 09 May 2009 09:42 Go to previous message
Antoine
> Elena.
Previous Topic:Missing Pseudo Translation packs for CDO and net4j
Next Topic:Non-translatable Strings and properties files in fragment
Current Time: Mon Jun 18 19:12:20 GMT 2018
Powered by FUDForum. Page generated in 0.02106 seconds
