Home » Eclipse Projects » Eclipse Platform » log4j setup/import problem
log4j setup/import problem [message #281405] Sat, 19 February 2005 17:29 Go to next message
Originally posted by: joan.bukoskey.verizon.net
I am new to Java and the Eclipse environment. When I code:
import org.apache.log4j.Logger; I have the following message:
import org.apache.log4j cannot be resolved. I have set up a Classpath
Variable as:
LOG4J - C:/LOG4J/logging-log4j-1.2.9/dist/lib/log4j-1.2.9.jar in
Preferences->Java->Build Path. Any help would be greatly appreciated.
Thanks, bill
Re: log4j setup/import problem [message #281408 is a reply to message #281405] Sat, 19 February 2005 18:42 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
Try adding the jar to your build path as "external jar".
Chris Laffra, http://eclipsefaq.org
"William Koch" <joan.bukoskey@verizon.net> wrote in message
news:cv7t1b$qnf$1@www.eclipse.org...
> Variable as:
> Thanks, bill
Re: log4j setup/import problem [message #281533 is a reply to message #281405] Mon, 21 February 2005 15:08 Go to previous message
> Variable as:
> Thanks, bill
You've defined the variable to tell eclipse where log4j lives, now you
need to include that variable in the classpath for your Project.
Right-click the Project, choose properties, then Java Build Path, then
Libraries (tab). There you can add the variable to that Project.
HTH,
Eric
Previous Topic:How do you set the initial window position when debugging?
Next Topic:need some guidelines in plugin development in Eclipse
Current Time: Sun May 27 15:57:41 GMT 2018
Powered by FUDForum. Page generated in 0.01810 seconds
