Home » Eclipse Projects » Eclipse Platform » SWT AS JSR
SWT AS JSR [message #280175] Mon, 31 January 2005 14:03 Go to next message
Eclipse User
Originally posted by: denisw.online.de
Why don`t you recommend SWT as Java Standards Request? When the API gets
changed to have almost the same classes (and more), it would be a great
replacement for AWT. SWT would then be in a java.swt package, or in
java.awt as an "AWT 2.0". What about that?
Re: SWT AS JSR [message #280187 is a reply to message #280175] Mon, 31 January 2005 16:36 Go to previous messageGo to next message
John Austin is currently offline John Austin
Member
What does it buy us ?
Re: SWT AS JSR [message #280189 is a reply to message #280187] Mon, 31 January 2005 17:17 Go to previous messageGo to next message
Jim Adams is currently offline Jim Adams
An what does it buy Java? It is terribly devisive already. What would be
gained?
SWT is not the best replacement for AWT, its just different.
"John Austin" <jwaustin@nl.rogers.com> wrote in message
news:ctm8ct$555$1@www.eclipse.org...
Re: SWT AS JSR [message #280220 is a reply to message #280175] Mon, 31 January 2005 21:26 Go to previous messageGo to next message
John Willson is currently offline John Willson
+1
"Denis Washington" <denisw@online.de> ??????:ctlvdm$ri0$1@www.eclipse.org...
Re: SWT AS JSR [message #280222 is a reply to message #280189] Mon, 31 January 2005 22:03 Go to previous messageGo to next message
Ian Phillips is currently offline Ian Phillips
Member
> gained?
Probably the only thing that could be said to be gained from this would
be if you were aiming for a shot at getting SWT included as a standard
part of the J2SE release.
That, and seeing flocks of pigs over Sun HQ of course...
Ian.
#ifndef __COMMON_SENSE__ | Ian Phillips
#include <std_disclaimer> | http://ianp.org
#endif
Re: SWT AS JSR [message #280251 is a reply to message #280222] Tue, 01 February 2005 09:44 Go to previous messageGo to next message
Eclipse User
Originally posted by: Chris_Laffra.ca.ibm.com
Funny. See http://www.eclipsefaq.org/chris/ under "standards".
Chris Laffra, http://eclipsefaq.org
"Ian Phillips" <ianp@ianp.org> wrote in message
news:ctmric$bs5$1@www.eclipse.org...
> > gained?
Re: SWT AS JSR [message #280299 is a reply to message #280251] Tue, 01 February 2005 14:21 Go to previous messageGo to next message
That is funny! So where is Doug now?
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:cto4ll$ljo$1@www.eclipse.org...
be
> > > gained?
Re: SWT AS JSR [message #280339 is a reply to message #280175] Wed, 02 February 2005 03:00 Go to previous messageGo to next message
Robert Enyedi is currently offline Robert Enyedi
Member
Before doing that, how about solving SWT's design and implementation
problems?
I think that what SWT does under the hood is just great. It's fast, has
a rich component set and is good looking. But, regarding it's API, some
parts of it are poorly designed. I'm talking about the constants inside
the huge SWT class (but only some constants made it there - see
GridData.FILL) and the inheritance issues. See the post from
http://javalobby.org/forums/thread.jspa?threadID=16852&t start=0
And parts of the implementation of SWT seem unfinished/hacked. For
instance, you can't have a button with both image and text. This is also
true for the label control, but there's a custom label control that has
both (no custom control for buttons). And when you set a button's image,
your button will no longer be consistent with the Windows XP theme (same
problem with buttons of SWT.ARROW type).
With Swing Sun didn't solve some tricky issues (in fact Swing is only
95% finished after 7 years of development), but such basic things were
solved right from the initial design.
So I hope that the people from the Eclipse SWT dev team aren't thinking
about standardization until problems like these aren't addressed...
Re: SWT AS JSR [message #280420 is a reply to message #280339] Wed, 02 February 2005 22:40 Go to previous messageGo to next message
Eclipse User
"Robert Enyedi" <renyedi@yahoo.com> wrote in message
news:ctq1ae$4ti$1@www.eclipse.org...
SWT is still evolving. Having performance as the main design
factor makes you choose certain tradeoffs that may come off
as inconsistencies or as things that are not well thought out.
To me personally, standardization makes sense when there are
multiple (competing/conflicting) implementations available
and customers need a standard to enforce stability in the
implementations. For SWT, there is only one provider, the
eclipse project, and there is little need for a standard (?).
Standards are very "expensive" to develop. You have
to ask yourself whether the benefits outweigh the costs.
If you see problems in SWT, please submit a PR and if
you have a solution, provide a patch with your bugzilla
report. Only when people help out can the eclipse team
solve all problems.
Re: SWT AS JSR [message #280421 is a reply to message #280175] Wed, 02 February 2005 22:40 Go to previous messageGo to next message
Eclipse User
I suggest you ask this question also at the eclipse.foundation newsgroup.
"Denis Washington" <denisw@online.de> wrote in message
news:ctlvdm$ri0$1@www.eclipse.org...
Re: SWT AS JSR [message #280485 is a reply to message #280175] Fri, 04 February 2005 00:40 Go to previous message
Eclipse User
Originally posted by: bob.objfac.com
Oh s***. You've kicked off the SWT vs. AWT/Swing permathread.
Bob Foster
Previous Topic:New Project Wizard
Next Topic:Reading config file
Current Time: Sat May 25 05:35:03 EDT 2013
Powered by FUDForum. Page generated in 0.01891 seconds
