Home » Eclipse Projects » Eclipse Platform » getItems() only works on expanded TreeItems
getItems() only works on expanded TreeItems [message #280158] Mon, 31 January 2005 14:47 Go to next message
Originally posted by: devin_steffler.ca.ibm.com
Can you explain the following? I don't see why TreeItems need to be
expanded in order for getItems() to return something useful.
// the following line only works if viewer.getTree().getItems()[0] is
expanded
TreeItem[] testing = viewer.getTree().getItems()[0].getItems();
viewer.setContentProvider(new ViewContentProvider(file));
// if I do viewer.expandAll(); here then below works fine, but not if I use
viewer.expandToLevel(Object, int)
Re: getItems() only works on expanded TreeItems [message #280230 is a reply to message #280158] Tue, 01 February 2005 08:04 Go to previous message
Originally posted by: scheglov_ke.nlmk.ru
Devin Steffler пишет:
> expanded
JFace TreeViewer is smart enough to don't ask for full tree content.
It creates real TreeItem's only when needed, i.e. when user expand some
visible item.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Previous Topic:Can't find helpsystem in web
Next Topic:EclipseClassLoader.getResource(String) returns a malformed URL
Current Time: Fri Apr 20 20:42:57 GMT 2018
Powered by FUDForum. Page generated in 0.01975 seconds
