Home » Eclipse Projects » Eclipse Platform » Eclipse CoLor Pallete in GIMP format to share?
Eclipse CoLor Pallete in GIMP format to share? [message #277507] Mon, 13 December 2004 10:24 Go to next message
Timur Shakirov is currently offline Timur ShakirovFriend
I'm trying to draw a couple of icons for my Eclipse plugin, and as I'm
using GIMP as a drawing tool, I'm lookig for an Eclipse 256 Color Palette
(see http://www.eclipse.org/articles/Article-UI-Guidelines/Conten ts.html)
in GIMP format (.gpl-file). Maybe somebody here has done the job already
and could share this palette?
WBW,
Timur Shakirov
Re: Eclipse CoLor Pallete in GIMP format to share? [message #278181 is a reply to message #277507] Fri, 24 December 2004 14:56 Go to previous message
Steve Jones is currently offline Steve JonesFriend
Member
Timur Shakirov wrote:
> Hello,
> WBW,
> Timur Shakirov
Him
If you copy the palette image from the eclipse style guide:
http://www.eclipse.org/articles/Article-UI-Guidelines/images /256palette.gif
In gimp (I'm using gimp 2.0.1) you open this image and do
File->Dialogue->Indexed Palette. Gimp will create the palette from the
image for you.
If you then go to File->Dialogue->Palettes. Create a palette called
"eclipse-icons" and save it. It should then appear in the list of palettes.
Select the palette in the list, right click, and select "Import". You then
have the option to select the current image as the source of the palette
data. Having done this your new palette will allways be available for new
icon design.
Cheers Steve.
Previous Topic:Change editor context menu
Next Topic:How to change the default size of "Properties" dialog ?
Current Time: Sun Jan 21 03:18:35 GMT 2018
Powered by FUDForum. Page generated in 0.01842 seconds
