Home » Eclipse Projects » Eclipse Platform » why does my eclipse often terminate suddenly in Redhat 7.2?
| why does my eclipse often terminate suddenly in Redhat 7.2? [message #274968] |
Tue, 02 November 2004 01:14  |
Originally posted by: zc.ssc.stn.sh.cn
I setup a Eclipse 3.0 in Redhat 7.2 on my PC. My jdk's version is 1.4.2_03
b2. When I run Eclipse, it often terminate suddenly, and the message is
jvm terminated, exit code = 6. The log file said that exception was
detected in the native code outside the VM.
Below is the log file in the eclipse homepath:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x40034BC7
Function=__pthread_mutex_lock+0x17
Library=/lib/i686/libpthread.so.0
Current Java thread:
at org.eclipse.swt.internal.motif.OS.XtSetValues(Native Method)
at org.eclipse.swt.widgets.MenuItem.setText(MenuItem.java:854)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:1162)
org.eclipse.jface.action.ActionContributionItem$1.propertyCh ange(ActionContributionItem.java:488)
org.eclipse.ui.internal.commands.ws.CommandCallback$1.comman dChanged(CommandCallback.java:91)
org.eclipse.ui.internal.commands.Command.fireCommandChanged( Command.java:143)
org.eclipse.ui.internal.commands.MutableCommandManager.notif yCommands(MutableCommandManager.java:389)
org.eclipse.ui.internal.commands.MutableCommandManager.setAc tiveContextIds(MutableCommandManager.java:580)
org.eclipse.ui.internal.commands.ws.WorkbenchCommandSupport. setActiveContextIds(WorkbenchCommandSupport.java:631)
org.eclipse.ui.internal.Workbench$2.contextManagerChanged(Wo rkbench.java:1812)
org.eclipse.ui.internal.contexts.AbstractContextManager.fire ContextManagerChanged(AbstractContextManager.java:46)
org.eclipse.ui.internal.contexts.ProxyContextManager$1.conte xtManagerChanged(ProxyContextManager.java:41)
org.eclipse.ui.internal.contexts.MutableContextManager.setEn abledContextIds(MutableContextManager.java:262)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. processEnabledSubmissions(WorkbenchContextSupport.java:611)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. processEnabledSubmissions(WorkbenchContextSupport.java:497)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport. access$1(WorkbenchContextSupport.java:496)
org.eclipse.ui.internal.contexts.ws.WorkbenchContextSupport$ 3.partDeactivated(WorkbenchContextSupport.java:270)
org.eclipse.ui.internal.PartListenerList$4.run(PartListenerL ist.java:91)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.PartListenerList.firePartDeactivated (PartListenerList.java:89)
org.eclipse.ui.internal.WWinPartService$1.partDeactivated(WW inPartService.java:51)
org.eclipse.ui.internal.PartListenerList2$4.run(PartListener List2.java:87)
org.eclipse.ui.internal.PartListenerList2.firePartDeactivate d(PartListenerList2.java:85)
org.eclipse.ui.internal.WorkbenchPage.firePartDeactivated(Wo rkbenchPage.java:1417)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2688)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2372)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:304)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 84)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:731)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:752)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:735)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:11 59)
at org.eclipse.swt.widgets.Control.XButtonPress(Control.java:29 43)
at org.eclipse.swt.widgets.Composite.XButtonPress(Composite.jav a:812)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:903)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3478 )
at org.eclipse.swt.internal.motif.OS.XtDispatchEvent(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2640)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:03 244788
/home/zc/j2sdk1.4.2_03/bin/java
0804e000-0804f000 rw-p 00005000 03:03 244788
40000000-40016000 r-xp 00000000 03:03 1547381 /lib/ld-2.2.4.so
40016000-40017000 rw-p 00015000 03:03 1547381 /lib/ld-2.2.4.so
40017000-4001f000 r-xp 00000000 03:03 244733
/home/zc/j2sdk1.4.2_03/jre/lib/i386/native_threads/libhpi.so
4001f000-40020000 rw-p 00007000 03:03 244733
40020000-4002a000 r-xp 00000000 03:03 1547415 /lib/libnss_files-2.2.4.so
4002a000-4002b000 rw-p 00009000 03:03 1547415 /lib/libnss_files-2.2.4.so
4002b000-4002c000 r--s 00000000 03:03 1889986
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.workbench.compatibility_3.0.0/compatibility.jar
4002d000-4003a000 r-xp 00000000 03:03 1221621
/lib/i686/libpthread-0.9.so
4003a000-40042000 rw-p 0000c000 03:03 1221621
40042000-40045000 r-xp 00000000 03:03 1547394 /lib/libdl-2.2.4.so
40045000-40046000 rw-p 00002000 03:03 1547394 /lib/libdl-2.2.4.so
40046000-40178000 r-xp 00000000 03:03 1221617 /lib/i686/libc-2.2.4.so
40178000-4017d000 rw-p 00131000 03:03 1221617 /lib/i686/libc-2.2.4.so
40181000-4057b000 r-xp 00000000 03:03 1156929
/home/zc/j2sdk1.4.2_03/jre/lib/i386/client/libjvm.so
4057b000-40597000 rw-p 003f9000 03:03 1156929
405a9000-405bc000 r-xp 00000000 03:03 1547399 /lib/libnsl-2.2.4.so
405bc000-405bd000 rw-p 00012000 03:03 1547399 /lib/libnsl-2.2.4.so
405bf000-405e1000 r-xp 00000000 03:03 1221619 /lib/i686/libm-2.2.4.so
405e1000-405e2000 rw-p 00021000 03:03 1221619 /lib/i686/libm-2.2.4.so
405e2000-405e6000 rw-s 00000000 03:03 554312 /tmp/hsperfdata_root/3342
405e6000-405f6000 r-xp 00000000 03:03 1890014
/home/zc/j2sdk1.4.2_03/jre/lib/i386/libverify.so
405f6000-405f8000 rw-p 0000f000 03:03 1890014
405f8000-40618000 r-xp 00000000 03:03 1890015
/home/zc/j2sdk1.4.2_03/jre/lib/i386/libjava.so
40618000-4061a000 rw-p 0001f000 03:03 1890015
4061a000-4062e000 r-xp 00000000 03:03 1890017
/home/zc/j2sdk1.4.2_03/jre/lib/i386/libzip.so
4062e000-40631000 rw-p 00013000 03:03 1890017
40631000-41fc9000 r--s 00000000 03:03 1156967
/home/zc/j2sdk1.4.2_03/jre/lib/rt.jar
42013000-42029000 r--s 00000000 03:03 1156932
/home/zc/j2sdk1.4.2_03/jre/lib/sunrsasign.jar
42029000-42104000 r--s 00000000 03:03 1156964
/home/zc/j2sdk1.4.2_03/jre/lib/jsse.jar
42104000-42115000 r--s 00000000 03:03 1156933
/home/zc/j2sdk1.4.2_03/jre/lib/jce.jar
42115000-4266e000 r--s 00000000 03:03 1156965
/home/zc/j2sdk1.4.2_03/jre/lib/charsets.jar
44716000-44719000 r--s 00000000 03:03 1596749
/home/zc/j2sdk1.4.2_03/jre/lib/ext/dnsns.jar
44719000-4471e000 r--s 00000000 03:03 1043087
/home/zc/eclipse-SDK-3.0-linux/eclipse/startup.jar
4471e000-4471f000 r--s 00000000 03:03 1010383
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.s wt.motif_3.0.0/ws/motif/swt-gtk.jar
4471f000-44720000 r--s 00000000 03:03 1156888
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i_3.0.0/ui.jar
4c923000-4c94e000 r--p 00000000 03:03 977305
/usr/lib/locale/en_US/LC_CTYPE
4cb52000-4cb6e000 r--s 00000000 03:03 1596748
/home/zc/j2sdk1.4.2_03/jre/lib/ext/sunjce_provider.jar
4cb6e000-4cb7b000 r--s 00000000 03:03 1596751
/home/zc/j2sdk1.4.2_03/jre/lib/ext/ldapsec.jar
4cb7b000-4cc37000 r--s 00000000 03:03 1596790
/home/zc/j2sdk1.4.2_03/jre/lib/ext/localedata.jar
4ccb8000-4ccf0000 r--s 00000000 03:03 1971386
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/core.jar
4ccf0000-4ccf8000 r--s 00000000 03:03 1971387
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/console.jar
4ccf8000-4cd04000 r--s 00000000 03:03 1971385
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/osgi.jar
4cd04000-4cd1a000 r--s 00000000 03:03 1971389
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/resolver.jar
4cd1a000-4cd30000 r--s 00000000 03:03 1971390
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/defaultAdaptor.jar
4cd30000-4cd4f000 r--s 00000000 03:03 1971388
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.o sgi_3.0.0/eclipseAdaptor.jar
4ce51000-4ce61000 r-xp 00000000 03:03 1890020
/home/zc/j2sdk1.4.2_03/jre/lib/i386/libnet.so
4ce61000-4ce62000 rw-p 0000f000 03:03 1890020
4ce62000-4ce68000 r-xp 00000000 03:03 1890021
/home/zc/j2sdk1.4.2_03/jre/lib/i386/libnio.so
4ce68000-4ce69000 rw-p 00005000 03:03 1890021
4ce69000-4ce7d000 r--s 00000000 03:03 1889990
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u pdate.configurator_3.0.0/configurator.jar
4ce7d000-4ce92000 r--s 00000000 03:03 1515434
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.runtime.compatibility_3.0.0/compatibility.jar
4ce92000-4cea5000 r--s 00000000 03:03 1010384
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.s wt.motif_3.0.0/ws/motif/swt-mozilla.jar
4cea5000-4cea6000 r--p 00000000 03:03 2019716
/usr/lib/locale/en_US/LC_IDENTIFICATION
4cea6000-4cea7000 r--p 00000000 03:03 1042449
/usr/lib/locale/en_US/LC_MEASUREMENT
4cea7000-4cea8000 r--p 00000000 03:03 146605
/usr/lib/locale/en_US/LC_TELEPHONE
4cea8000-4cea9000 r--p 00000000 03:03 146607
/usr/lib/locale/en_US/LC_ADDRESS
4cea9000-4ceaa000 r--p 00000000 03:03 146606
/usr/lib/locale/en_US/LC_NAME
4ceaa000-4ceab000 r--p 00000000 03:03 879584
/usr/lib/locale/en_US/LC_PAPER
4ceab000-4ceac000 r--p 00000000 03:03 162903
/usr/lib/locale/en_US/LC_MESSAGES/SYS_LC_MESSAGES
4ceac000-4cead000 r--p 00000000 03:03 1042448
/usr/lib/locale/en_US/LC_MONETARY
4cead000-4ceb3000 r--p 00000000 03:03 537522
/usr/lib/locale/en_US/LC_COLLATE
4ceb3000-4ceb4000 r--p 00000000 03:03 2019717
/usr/lib/locale/en_US/LC_TIME
4ceb4000-4ceb5000 r--p 00000000 03:03 977300
/usr/lib/locale/en_US/LC_NUMERIC
4ceb6000-4ceb8000 r-xp 00000000 03:03 1124010
/usr/lib/gconv/ISO8859-1.so
4ceb8000-4ceb9000 rw-p 00001000 03:03 1124010
4ceba000-4cec6000 r-xp 00000000 03:03 1270611
/usr/X11R6/lib/libXext.so.6.4
4cec6000-4cec8000 rw-p 0000b000 03:03 1270611
4cec8000-4cece000 r-xp 00000000 03:03 1270623
/usr/X11R6/lib/libXp.so.6.2
4cece000-4ced0000 rw-p 00005000 03:03 1270623
4ced0000-4ced4000 r-xp 00000000 03:03 1270631
/usr/X11R6/lib/libXtst.so.6.1
4ced4000-4ced6000 rw-p 00003000 03:03 1270631
4ced6000-4cedd000 r-xp 00000000 03:03 1270601
/usr/X11R6/lib/libSM.so.6.0
4cedd000-4cedf000 rw-p 00006000 03:03 1270601
4cedf000-4cee4000 r--s 00000000 03:03 1124062
/usr/lib/gconv/gconv-modules.cache
4cee4000-4cee5000 r-xp 00000000 03:03 1873933
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.resources.linux_3.0.0/os/linux/x86/libcore_2_1_0b.so
4cee5000-4cee6000 rw-p 00001000 03:03 1873933
4cee6000-4cf3d000 r--s 00000000 03:03 1189827
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.runtime_3.0.0/runtime.jar
4cf3d000-4cfbb000 r--s 00000000 03:03 1955064
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j face_3.0.0/jface.jar
4cfbb000-4d001000 r-xp 00000000 03:03 554216
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.s wt.motif_3.0.0/os/linux/x86/libswt-motif-3062.so
4d001000-4d004000 rw-p 00046000 03:03 554216
4d004000-4d018000 r-xp 00000000 03:03 1270597
/usr/X11R6/lib/libICE.so.6.3
4d018000-4d019000 rw-p 00013000 03:03 1270597
4d01b000-4d047000 r--s 00000000 03:03 912923
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.t eam.core_3.0.0/team.jar
4d047000-4d195000 r--s 00000000 03:03 1515470
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.ide_3.0.0/ide.jar
4d195000-4d3c8000 r--s 00000000 03:03 1124380
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.workbench_3.0.0/workbench.jar
4d3c8000-4d4c5000 r--s 00000000 03:03 1010385
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.s wt.motif_3.0.0/ws/motif/swt.jar
4d4c5000-4d649000 r-xp 00000000 03:03 1043090
/home/zc/eclipse-SDK-3.0-linux/eclipse/libXm.so.2.1
4d649000-4d65c000 rw-p 00183000 03:03 1043090
4d65d000-4d736000 r-xp 00000000 03:03 1270603
/usr/X11R6/lib/libX11.so.6.2
4d736000-4d73b000 rw-p 000d8000 03:03 1270603
4d73b000-4d783000 r-xp 00000000 03:03 1270629
/usr/X11R6/lib/libXt.so.6.0
4d783000-4d787000 rw-p 00047000 03:03 1270629
4d787000-4d825000 r--s 00000000 03:03 1010377
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.resources_3.0.0/resources.jar
4d8a6000-4d8b6000 r--s 00000000 03:03 2118129
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.h elp_3.0.0/help.jar
4d9b8000-4d9c6000 r--s 00000000 03:03 244508
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.views_3.0.0/views.jar
4d9c6000-4d9e0000 r--s 00000000 03:03 1955040
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.externaltools_3.0.0/externaltools.jar
4d9e0000-4dac0000 r--s 00000000 03:03 619691
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.d ebug.ui_3.0.0/dtui.jar
4dac0000-4daf8000 r--s 00000000 03:03 147022
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.d ebug.core_3.0.0/dtcore.jar
4daf8000-4db05000 r--s 00000000 03:03 1043069
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.expressions_3.0.0/expressions.jar
4dc07000-4dc0d000 r--s 00000000 03:03 1010290
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u pdate.scheduler_3.0.0/scheduler.jar
4dc0d000-4dc37000 r--s 00000000 03:03 1369010
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.t ext_3.0.0/text.jar
4dc37000-4dcce000 r--s 00000000 03:03 1010350
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j face.text_3.0.0/jfacetext.jar
4dcce000-4e1e4000 r--s 00000000 03:03 1743504
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.ui_3.0.0/jdt.jar
4e1e4000-4e222000 r--s 00000000 03:03 636057
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.editors_3.0.0/editors.jar
4e222000-4e27f000 r--s 00000000 03:03 163617
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.u i.workbench.texteditor_3.0.0/texteditor.jar
4e27f000-4e54c000 r--s 00000000 03:03 1043078
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.core_3.0.0/jdtcore.jar
4e5cd000-4e5e5000 r--s 00000000 03:03 65978
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.l tk.core.refactoring_3.0.0/refcore.jar
4e5e5000-4e5f1000 r--s 00000000 03:03 1678471
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ore.filebuffers_3.0.0/filebuffers.jar
4e5f1000-4e611000 r--s 00000000 03:03 912864
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.l tk.ui.refactoring_3.0.0/refui.jar
4e611000-4e671000 r--s 00000000 03:03 244678
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.s earch_3.0.0/search.jar
4e671000-4e67d000 r--s 00000000 03:03 1873906
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.debug_3.0.0/jdi.jar
4e67d000-4e6de000 r--s 00000000 03:03 146993
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.c ompare_3.0.0/compare.jar
4e6f2000-4e71f000 r--s 00000000 03:03 1955106
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.launching_3.0.0/launching.jar
4e71f000-4e787000 r--s 00000000 03:03 1010327
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.p de.core_3.0.0/pdecore.jar
4e787000-4e797000 r--s 00000000 03:03 1889935
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.p de_3.0.0/pde.jar
4e900000-4e9e2000 r--s 00000000 03:03 1368945
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.debug.ui_3.0.0/jdiui.jar
4e9e2000-4ea8d000 r--s 00000000 03:03 1873905
/home/zc/eclipse-SDK-3.0-linux/eclipse/plugins/org.eclipse.j dt.debug_3.0.0/jdimodel.jar
Heap at VM Abort:
Heap
def new generation total 1920K, used 98K [0x44720000, 0x44930000,
0x44c00000)
eden space 1728K, 1% used [0x44720000, 0x44726998, 0x448d0000)
from space 192K, 37% used [0x448d0000, 0x448e21c8, 0x44900000)
to space 192K, 0% used [0x44900000, 0x44900000, 0x44930000)
tenured generation total 24948K, used 17461K [0x44c00000, 0x4645d000,
0x48720000)
the space 24948K, 69% used [0x44c00000, 0x45d0d5f8, 0x45d0d600,
0x4645d000)
compacting perm gen total 24064K, used 23981K [0x48720000, 0x49ea0000,
0x4c720000)
the space 24064K, 99% used [0x48720000, 0x49e8b678, 0x49e8b800,
0x49ea0000)
Local Time = Tue Nov 2 14:01:56 2004
Elapsed Time = 67
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_03-b02 mixed mode)
Who can help me?
| Re: why does my eclipse often terminate suddenly in Redhat 7.2? [message #274979 is a reply to message #274968] |
Tue, 02 November 2004 04:52   |
Tom Hofmann Messages: 770 Registered: July 2009 |
Points that may explain / help:
- RH 7.2 is not supported any longer
- make sure the correct libXm.so library (the one in your eclipse
install) gets picked up.
- ask on the eclipse.platform.swt newsgroup.
-tom
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Dynamic libraries:
> Heap at VM Abort:
> Heap
> 0x44c00000)
> 0x48720000)
> 0x4645d000)
> 0x4c720000)
> 0x49ea0000)
> Elapsed Time = 67
> Who can help me?
| Re: why does my eclipse often terminate suddenly in Redhat 7.2? [message #274989 is a reply to message #274968] |
Tue, 02 November 2004 09:01   |
Grant Gayed Messages: 2141 Registered: July 2009 |
Bruce,
You'll need a download either 3.0.1 or a recent 3.1-stream build to make
this work on your setup, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47549 .
Grant
"Bruce Zhao" <zc@ssc.stn.sh.cn> wrote in message
news:cm78jj$9qa$1@eclipse.org...
> at
m.java:1162)
> at
> at
Callback.java:91)
> at
> at
> at
> at
> at
2)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
:615)
> at
t.java:89)
> at
va:51)
> at
> at
:615)
> at
st2.java:85)
> at
:1417)
> at
> at
372)
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> Dynamic libraries:
s/motif/swt-gtk.jar
ar
e.jar
ar
er.jar
tAdaptor.jar
eAdaptor.jar
0/runtime.jar
..jar
eam.jar
jar
0/workbench.jar
s/motif/swt.jar
0.0/resources.jar
ar
ews.jar
ui.jar
dtcore.jar
3.0.0/scheduler.jar
ar
jfacetext.jar
jar
editors.jar
tcore.jar
g_3.0.0/refui.jar
ch.jar
di.jar
pare.jar
..0/launching.jar
ecore.jar
0/jdiui.jar
dimodel.jar
> Heap at VM Abort:
> Heap
> 0x44c00000)
> 0x48720000)
> 0x4645d000)
> 0x4c720000)
> 0x49ea0000)
> Elapsed Time = 67
> Who can help me?
| Re: why does my eclipse often terminate suddenly in Redhat 7.2? [message #275030 is a reply to message #274989] |
Tue, 02 November 2004 22:16  |
I will try the 3.0.1.
Grant Gayed wrote:
> Bruce,
> Grant
>> at
> m.java:1162)
>> at
>> at
> Callback.java:91)
>> at
>> at
>> at
>> at
>> at
> 2)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> :615)
>> at
> t.java:89)
>> at
> va:51)
>> at
>> at
> :615)
>> at
> st2.java:85)
>> at
> :1417)
>> at
>> at
> 372)
>> at
>> at
> java:335)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
> ..java:25)
>> Dynamic libraries:
> s/motif/swt-gtk.jar
> ar
> e.jar
> ar
> er.jar
> tAdaptor.jar
> eAdaptor.jar
> 0/runtime.jar
> ..jar
> eam.jar
> jar
> 0/workbench.jar
> s/motif/swt.jar
> 0.0/resources.jar
> ar
> ews.jar
> ui.jar
> dtcore.jar
> 3.0.0/scheduler.jar
> ar
> jfacetext.jar
> jar
> editors.jar
> tcore.jar
> g_3.0.0/refui.jar
> ch.jar
> di.jar
> pare.jar
> ..0/launching.jar
> ecore.jar
> 0/jdiui.jar
> dimodel.jar
>> Heap at VM Abort:
>> Heap
>> 0x44c00000)
>> 0x48720000)
>> 0x4645d000)
>> 0x4c720000)
>> 0x49ea0000)
>> Elapsed Time = 67
>> Who can help me?
Current Time: Tue Oct 08 07:50:09 EDT 2013
Powered by FUDForum. Page generated in 0.02167 seconds
