Home » Modeling » M2T (model-to-text transformation) » Xpath node
Xpath node [message #27223] Wed, 18 July 2007 15:08 Go to next message
Zsolt Paroczi is currently offline Zsolt ParocziFriend
How can I access an Xpath node in a custom tag or in a custom Xpath
function source code?
Thanks forward,
Zsolt
Re: Xpath node [message #27356 is a reply to message #27223] Thu, 19 July 2007 13:40 Go to previous message
Paul Elder is currently offline Paul ElderFriend
Zsolt:
From a tag:
To evaluate the XPath expressions yourself in the tag handler (like c:get
and c:iterate), you need to use the class XPathContextExtender:
XPathContextExtender xce = XPathContextExtender.getInstance(context);
// there is a whole family of resolveXXX methods. To resolve an xpath as a
boolean, you'd use:
boolean result = xce.resolveTest(currentXPathContext(),
getAttribute("test");
From an XPath function:
You can use the XPathUtil class to convert function arguments into the
desired primitive type (String, number, boolean).
In either case
If you are looking for a model 'node', the XPath engine returns a
org.eclipse.jet.xpath.NodeSet, which is an extension of java.util.Set (so
you can use .iterator() to traverse the set's elements). The type of the
actual object returned will depend on the 'modelLoader' you used. The
org.eclipse.jet.emf and org.eclipse.jet.emfxml loaders will return you
EObject's (or subtypes). If you use the org.eclipse.jet.resource model
loader, you will get org.eclipse.core.resources.IResource objects.
Paul
"Zsolt Paroczi" <paroczizs@ext.t-mobile.hu> wrote in message
news:970dee2d93c5bcdbb487dddde8766e40$1@www.eclipse.org...
> Thanks forward,
> Zsolt
Previous Topic:Passing XPath result to custom tag
Next Topic:[JET2] Re: JET2: Invalid Java source folder
Current Time: Wed Jun 20 21:20:07 GMT 2018
Powered by FUDForum. Page generated in 0.01322 seconds
