Home » Newcomers » Newcomers » Is there a better file diff/comparison/merge plugin for Eclipse?
Is there a better file diff/comparison/merge plugin for Eclipse? [message #272094] Thu, 09 July 2009 17:21 Go to next message
Dave Kong is currently offline Dave KongFriend
I'm using SVN + Eclipse.
While the default file diff tool is adequate, it lacks color coded diff
markers which I'm more used to. I use TortoiseSVN and I like its
diff/merge tool much more.
There has to be other diff/merge plugins for eclipse, right?
-dave
Re: Is there a better file diff/comparison/merge plugin for Eclipse? [message #272096 is a reply to message #272094] Thu, 09 July 2009 22:11 Go to previous message
No, there's not.
If you can elaborate on what you'd like to be improved, enter it as an
enhancement request in Bugzilla: https://bugs.eclipse.org/bugs
Eric
Previous Topic:Need to change the default Launch Configuration name
Next Topic:Accessing bugzilla via XML-RPC
Current Time: Mon Feb 19 10:25:26 GMT 2018
Powered by FUDForum. Page generated in 0.03068 seconds
