Home » Newcomers » Newcomers » Auto completion of return type
Auto completion of return type [message #271614] Tue, 16 June 2009 04:49 Go to next message
Originally posted by: fastcodejava.gmail.com
Is there any way to get returned object auto created? E.g.,
someObject.someMethod(); After auto completion it becomes
SomeClass some = someObject.someMethod(); Is there code template that
will do the trick?
--Gautam
Re: Auto completion of return type [message #271617 is a reply to message #271614] Tue, 16 June 2009 07:59 Go to previous messageGo to next message
Gautam,
Shift-Alt-L will pull a complete expression into a local variable and
replace its use with that variable...
G Gev wrote:
> will do the trick?
> --Gautam
Re: Auto completion of return type [message #271628 is a reply to message #271617] Wed, 17 June 2009 03:22 Go to previous messageGo to next message
Hi Ed,
That worked nicely! But it doesn't work on expressions if there is a
cast in front it, e.g. (IMethod)javaElement.
--Gautam
Ed Merks wrote:
> Gautam,
> G Gev wrote:
>> will do the trick?
>> Thanks,
>> --Gautam
Re: Auto completion of return type [message #271644 is a reply to message #271628] Wed, 17 June 2009 11:12 Go to previous messageGo to next message
Gautam,
Is that true even if you have the cast selected too? I use
Alt-Shift-UpArrow to select the whole expression, the containing
expression of that, and so on...
G Gev wrote:
> Hi Ed,
> --Gautam
> Ed Merks wrote:
>> Gautam,
>> G Gev wrote:
>>> Hi,
>>> that will do the trick?
>>> Thanks,
>>> --Gautam
Re: Auto completion of return type [message #271674 is a reply to message #271644] Mon, 22 June 2009 05:36 Go to previous messageGo to next message
--------------050901070007090403030904
Hi Ed,
I get an error if I select the cast. I am attaching the error.
--Gautam,
Ed Merks wrote:
> Gautam,
> G Gev wrote:
>> Hi Ed,
>> Thanks,
>> --Gautam
>> Ed Merks wrote:
>>> Gautam,
>>> G Gev wrote:
>>>> Hi,
>>>> Thanks,
>>>> --Gautam
Content-Type: image/jpeg;
name="error1.jpg"
Content-Disposition: inline;
filename="error1.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CALGAbkDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDY8f8Aj/WPC3iG10zTLOwm SW0il/fW5dy7
EjAwR6Cs248c/EK0RXuNB0iMMNwDQqDj6eZkVL4xMI+Mugmfbs+wR43dN2JN v64qPxFrWn3M
p+2XiK6fKR50gx/5BNejSpQcY+7fQzd9XcxZPjL4nhkMcmn6Qrjgg2p/+KpB 8aPEZ/5cdH/8
BT/8VXLajJp8ur2T2MwlPmgORIz45GPvRp7+v4d/T/F9jeat8S1sr3RdYu9I ab53uruRbRE2
LuliwqhNvJOWYHnjmtp0qMWly73/AAt/mYc0m3rtb8b/AORzY+M3iM/8uWj/ APgKf/iqcPjJ
4iP/AC5aR/4Cn/4qui0PStP0fVry10nS0u7S68OzNbXrPKzakxCllChht542 KAwx15rHPhzR
xpfhuJ9Bht9X1iaWJvtFzNHFbskwG1kLbjxlMbgeepOCIUaDduT+tf8AIpua V7/1p/mVx8Yv
EJ/5ctI/8BT/APFU4fGHxD/z5aR/4Cn/AOKrel8C+HRf6MJ7GW1eZ7qNrZ99 uLp48bFAeR2U
N2IbkdMZFQaLa3EXhXxLaHwelveSW9tINP8A9IZrgCZhu2F/MAGOx7Z6HFL9 xa6j/V7B+8vZ
syh8X/EH/PlpP/gKf/iqcPi74gP/AC56T/4Cn/4qoPDNld3/AMNvFFtZ2k1x O1xa4hhjLtwx
JwBk8Vr6X4O0ltHsftenP5clncSX+pPJIrWc6dEK5Cgg8YYZOfaqlChG947f 5XFF1Haz3/zs
UR8W9fP/AC56T/4DH/4qrFr8TvFF9OILTS9PuJSCRHFZM7EDknANPl8J2rXG mWumaLBc2NxB
A51i4mlCNIzgMCVYL1+TYAG966XSvDun6Pr+j3NrZSWk8gvYZlaN4w+xDhgj yOQD2O7kc4qJ
qhFP3e/4Dj7STWu9vxOTHxY14/8ALnpX/gMf/iqcPitrp/5dNL/8Bj/8VUPg eKPXtOvfDNw4
VHmivYmZsBdjASdf9gk/8BrptL0qy8Y6nNq9/ZpdWt5fPbxGFZWkgjVfl3sJ FWMYC4yrZJ9x
VThRg2nHb/gf8H7iYym1e/8AX/DfmYI+Kmun/l00v/wG/wDr04fFLXD/AMum l/8AgN/9etDS
tJ0SxXwsfsEzX2oXLxm5S7eMptmA3YU9dvHBGMk8npcHg7TpLbUJbmzEu+O7 lhuYfNYoUc7Q
8hk27+Pu7D05Oc1LVBauPf8AApe0btf+mZcvxF8S27RrPpljE0qB4w9mVLqe hGTyD60s/wAR
vEVpcPBc6dYQTJw0cloVZfqCcitvU9LtbzSbW6vbLYltots8F9ucfvd3EfXa c+mM89elWta0
TR7jWdU1C50+51S4+3LHNb2sbSSRR+WuMKsiFc8/MQw46VNqN7OPf80v1C82 r37fk2cuPibr
R/5ddM/8Bv8A69OHxL1o/wDLrpv/AIDf/Xrj7lEju5kjWVY1kYKsow4GeAw7 H1poroWHpNX5
TN1Jp2udoPiTrJ/5ddN/8Bv/AK9OHxI1g/8ALrpv/gP/APXrjBTxR9Xpfyi9 rPudkPiNrB/5
dtO/8B//AK9OHxE1f/n207/wH/8Ar1x4p4o+r0v5Q9rPudePiFq5/wCXbTv/ AAH/APr04fEH
Vj/y7af/AOA//wBeuRFPFL6vS/lD2s+51o8f6sf+XbT/APwH/wDr04ePdVP/ AC76f/4D/wD1
65MU8UfV6XYPaz7nVjx3qh/5d7D/AMBx/jTh451Q/wDLvYf+A4/xrlhTxS+r 0uwe1n3OoHjj
U/8An3sf/Acf404eNtT/AOeFj/4DiuYFPFH1en2D2s+50w8aakf+WFj/AOA4 pw8Zaif+WFl/
34Fc0KkFH1en2D2s+50Y8Yaif+WFl/34FOHi7UD/AMsLL/vwK50U8UvYU+we 1n3OhHi2/P8A
yxs/+/Apw8V3/wDzxs/+/ArAFPFHsKfYPaz7m8PFN8f+WNn/AN+BTh4ovj/y xtP+/ArBFSCl
7Cn2D2s+5uDxNe/88rT/AL8CnDxJen/llaf9+BWIKeKPYU+wvaz7m0PEV4f+ WVr/AN+BTh4g
u/8Anla/9+FrHFPFHsKfYPaz7muNeu/+eVt/35WnDXbr/nnbf9+VrJFPFL2F PsHtZ9zVGt3R
/wCWdt/35WnDWbk/8s7f/vytZYp4o9jT7B7Wfc0xq9wf+Wdv/wB+V/wpw1W4 P8Fv/wB+V/wr
OFPFL2NPsHtZ9zQGqTn+CD/vyv8AhThqUx/gg/78r/hVAVIKPY0+we1n3NSC eedHfdaoqkAl
oR1OfRT6GpN8n/Pey/78H/4iq1r/AMeU3/XRP5NXlX9k3X27z/7I1H/hCPtu 7+yNp8zfn/Xf
Z9m/7Pv58nOc/Ptx8tcVVqM3FJHXSTlFNs9Hv9YydSsYniaa3tfMd44Qu3cr YwcA5+XPHqOf
T59r2eT/AJD3iX/rzh/9Akrxiolsn5FR6o9U+IfgXVvEviS21DT7m0hSKzii /eu6tuGWyMKf
7wrnb74b+LtSVBeanpcpQYDEsGP1Ijyfxr2S5/1q/wDXNP8A0EVDVxxdSCUV 0G6aep4mPg94
gA4vNM/7+yf/ABFOHwg8QD/l80z/AL+yf/EV7VRV/XqxPsIHi4+EWvj/AJfN N/7+yf8AxFOH
wk14f8vem/8AfyT/AOIr2aij69WD2EDxsfCbXh/y96b/AN/H/wDiKcPhRrv/ AD96d/38f/4i
vYqKPr1YPYQPHx8Kdd/5+9O/7+P/APEU4fCvXB/y9ad/38f/AOIr16il9erB 7CB5GPhbrg/5
etP/AO/j/wDxFOHwv1v/AJ+tP/7+P/8AEV61RR9erB7CB5OPhjrQ/wCXrT/+ /j//ABFOHwy1
of8AL1Yf9/H/APiK9Woo+vVQ9hA8rHw01kf8vNh/38f/AOJpw+G2sj/l5sP+ /j//ABNepUUf
XaovYQPLx8ONY/5+bH/vt/8A4mnD4c6uP+Xmx/77f/4mvTqKPrtUfsIHmY+H erj/AJeLH/vt
/wD4mnD4e6sP+Xiy/wC+3/8Aia9Koo+u1Rewgebj4f6qP+Xiy/77b/4mnDwD qo/5eLP/AL7b
/wCJr0ail9dqh7CB52PAeqD/AJeLP/vtv/iacPAmqf8APez/AO+2/wDia9Co o+u1Q+rwPPx4
G1Mf8t7T/vtv/iacPBGpj/lvaf8Afbf/ABNd9RR9cqh9XgcGPBWpD/lvaf8A fbf/ABNOHgvU
R/y2tf8Avtv/AImu6oo+uVQ+rwOHHg3UR/y2tf8Avpv/AImnDwfqA/5bWv8A 303/AMTXbUUf
XKofV4HFjwjqH/Pa2/76b/4mnDwlf/8APa2/76b/AArsqKPrlUPq8Djx4Uvh /wAtbb/vpv8A
CnDwtfD/AJa2/wD303+FddRR9cqh9XgcmPDF6P8Alrb/APfTf4U4eGrwf8tY P++j/hXVUUvr
lUPq8Dlx4cvB/wAtIP8Avo/4U4eHbv8A56Qf99H/AArpqKPrdUPq8Dmx4fux /wAtIf8Avo/4
U4aDdD/lpD+Z/wAK6Kij63UD6vA58aHdf89IfzP+FOGiXI/ji/M/4VvUUfW6 gfV4GGNGuB/H
F+Z/wpw0i4/vxfmf8K2qKPrdQPq8DHGlT/34/wAz/hThpc/96P8AM/4VrUUv rdQPq8DLGmzD
+KP8z/hThp8o/iT8z/hWlRR9aqB9XgZ4sZR/En5mnCzkH8S/nV6ij61UD6vA pi1cd1/OnC2c
d1q1RR9aqB9XgZ17p9xdwrFHqNzaIG3N9mZQWPbJKk8ZPT1+lUf+Ecuf+hg1 b/v8n/xFb9FQ
6rk7tItU0lZM58aINNtdTuTeXNzLPblXedlJwqtjoo/vGvD6+htT/wCQVef9 cH/9BNfPNLmc
tx8tj6Wuf9av/XNP/QRVd3WNGd2CqoySewqxc/61f+uaf+gisbWLsWsIduVj VpmHrtwFH03s
lQk27IpuyuRX+qJAoM8rwg8rDHjzCPUk5C/TGfcGsuTUboWLX8enXBtVbBuD cTYB/wC+8fpX
JXGpPcTPNK5LMckk1tSatrEXw5mdLq2bSuSYwD5xXzNpAPTG4/Wve+oUqUI8 yu20tX+RwfWJ
zbtsbuleIYrt/KV3aQc+TJguR3KsAN30IB9M10COsiK6MGVhkEdxXhC6y0c6 Sxh0dGDKwPII
717F4f1AahYpOAAJY1mAA4BbIYD23q+K4cwwaw7Uo7M3w9Z1FZ7mnPPHbW8s 8rBY4kLux7AD
JrDsvFlrLpcd1fxSWc7ztbm2VHmcOF3BQFXJJTDdO9aer6cNW0uawaVoo58L Iy9SmRuUc8ZG
RntnNZVr4TisdZS9tryfyRIszQzu8zNII3jJ8x2J5Vl4/wBj3rzl5nQzUXWb B9KGprMfsp/i
8tt2c7duzG7du+XbjOeMZqCPxHpTrGTcPF5hdQJ4JIipRdzBgyjadvzYbGRy Miq914aju/Ds
+kyzIwknacM8IddxlMoDIThlzwRnkZ6dqTeDUn0ldNmbTre280zumm2H2YM4 A2Nje3KkZPrh
R0BBBmgvizRmnWLz51YusZZ7SZVVmAKqzFcKSGXAJB5A60q+KtJe0iuo5bmW KXPl+VZzOzgA
EsqhCSo3DLAYBOM54rLj8O6teT30OoXtuLKa7indY7Yh5mRI/mDeYQil0+6V JwDzzmpb7wdH
d2WkxFrGaXT4Ps4+32IuInUhQTs3AhsqMEN3I5p6WEaDeKdGSUobslVTe0yw uYlGzfzIBsB2
84JzjHHNRjxXpmWdpXiiSNmfz4JYpAQUAAjZATnzFx3JIABzxQfwhM100kd3 YW8Zh8sx29gU
En7rYFkHmbZIxyQrKSBwGFMj8FzKoZtUCypkwrFAwigbfE6hEZ22oDEPkBx8 xxto0uBpt4s0
dY0bzrgs+/ES2cxlGwgNmMJuGNy9QOCD0q1d67p1lZW13NOxhuceQYonlMmV LcBQSflBPTtV
HT/DktrqUmo3N6k11OsvnGOExoS/lgFQWJACxKMZOck57VPHoXl2Wj2/2nP9 nKBu2f6z900f
rx97PfpSe3n/AMP/AMAa3H2fiTSdQmSK1u97yMFQeU678qWBBI5UhWww4ODz SHxLpX2lLdZ5
Xkd9n7u3kcId5j+chSEBZSAWwDg4rOXwpcW7Wc9pqUaXNpDBFG0tsXQ+WkiE socE5Eh4BGCB
yelRxeELmO6tZv7ThDRSF5Jo7UxztmVpCgkWQfId2CjBgcZxno3a+mwtbFke KBc+GdT1S2t5
IpLITfLcQyKpKFgDlguQduTjp06irSeKNKeGR/Nn3xsqGE2kolJYEjbHt3sC ATkAjCk9jUf9
gznRNT0s3qGK7MxhfyPmi8wsx3fN8+Cxxjbx+dZ994Nk1Qtc6jdWNzfb4yvm WG632oHAVomc
k/6xzncOcenKH/wTdbWbBdKGpGZvspwAfLbfuzt27Mbt27jbjOeMZqs3ijSV SN2luAHBJzaT
ZiAYrmQbcxjIbl8Dg+hpjaDnw0NJRNLTkEounj7Mfn3Y8kv0P+915rIbwJuk hnln0++nEfly
NqlgbsY3sw8stJvXG4jlm4A9KelxdDTtvFNotvm/cpL5sqnyYJHWNFlZFZyo IQHb95iBwfQ4
fqXimxsbbUJIkubmSyjZ3EdtKYyV6r5gQrnnkZJHOehrLn8CRPdi5B0u4c7w 41DTRcKAZXkG
z51KkbyDyQcDgVoN4fuzZ6hpw1CEabdLNsjFsfNiaQkn59+CASTjb7ZpaD6l qPxJpkk8UO+4
V5Cq/PaSqqM3RXYqAjHIwrEHkccjMFl4kt9T12Kzsi0ls1vJKZmt5EVirIo2 OwCuvzHlc9uf
Wivg8nWf7SuDo9zNI6STPNpe6QMoC5ifzMoMKCAd2Dk98Vd0jQLvTry2kn1G O4htLVrW3jW2
8tghKEFm3Hc2EAyAAfQU1b+vQWtgHiywS6v4LlLmI2tyLdcW0r+cxUNhAE+Y 8n5VycDd0rTj
1O1m0wajC0ktsU3gxxOzkdxsA3ZHTGMg8YrJufD142ozXlpqUULG5F1CslqZ Nknl+UwbDjcp
XsMEHnJHFPfw4W8MtpIux5juZZZWjJSR2k8xwyBhlGJIK7uhxml08x9Sc+Jt LFskwe5be7Ri
FbOZptwGTmIJvGAQclccj1FUx4ws/tt1byxTQrbTNGzyQTDcqxeYSv7vBPX5 c5wM9wDX0/wj
c6S3n6de2FtdGR2Kpp+23COqAqI1kBHMYIO7uc561dXw9P8A219te9je3Nx9 paD7PyXMPlEb
t33cYOMZ68mnp+H4/wBf11EX59ZsrfzAWmlMaJIy29vJM21yQpwiknO09One qL+LNPS+tIv3
v2e4t5Lj7QYZAsYRgCH+X5MZOdxG3GD1FVJvB+/SVslu4ZNtwJSt1bmWGRFX Ykbxhl3BVC9/
vLnHamL4L2abBYrexpCIbm3mVLUKrRzNuIQBsIVwAPvDHalp/Xp/mBvafq1p qfmC2MwaPG9J
7eSFwD0O11BwcHBxjg+lc/B45tpb2NZLe5igK3G4fY53ctHIqgqAmSMEk4Bx 0JGK0vD2gjQ0
mHlaUpk2jdYacLUtjP38O27r7Y59aZYeHprPUXne+SWEC4WKMQbWUTSCQ7m3 ENgggYA4P5j0
en9aAttRx8WaUgdnnLpu+T7NFLMSmxHLkKnAAdeeRyOcnAv3WrWVnd21pNI/ n3IJiRIncsAQ
CflBwBuGSeBnNc1/wg8yWkUEOpQqyY/fm1bzo/3cceYnWRWjbEZ7kHdgggc9 I+nCTVIL1pSR
FbyQFCOW3FDnP/APTvTdun9af5gZt94v0+DSr+7thPO9tbtMifZpVEwHAKMV w65Iyy5ABBzi
n6dr6eXaw6jJMbq4ICyDS7i2iyTgKS4IU8Y5bJ445FZtj4HjsbC8sozpaJNa vbJcQ6aI7jae
hkkD4f3+Vcnnipr/AMHC/wBb/tCS4tWAnimUy2m+ePZt+RJS/wAqHB4C9WJz zRoDLN54usLe
1NxBFeXKCeOEslnNsbc+3cjBCHA5Py5zwO4qZvFejI8yvdOghR3d3t5FT5Bl wGK4LKOqgkjB
yODVdfD+ojSBpp1S3MNu0TWbfYzuTy3DKJP3mH4UA4CVVufB9xeQvbT6pGbQ NPLCi2uHSWVW
DEtv+ZR5j4XAPIyxxyK39f1/XcZoN4r0yOXbJJIquF8pRbzGWQnfwI9mekbE Yzn8srL4u0WG
COZrmZkeMyny7WVzGoJUlwqkxjII+bHIPoafLoXm+IYdV+048vZ+62ddqyr1 z/01z0/h9+Od
1bw9q9t9pttJDTLqMbxXMjwoY0DSuw5MyspAlbJCvnA4zwTS4uh3Q5GaKr20 NxFJcGa585Hk
DRJ5YXyl2gbcj73IJyf72O1WKQBRRRQMKKKKACiiigAooooAKKKKAKup/wDI KvP+uD/+gmvn
mvobU/8AkFXn/XB//QTXzzVRJZ9LXP8ArV/65p/6CK57xJbyT2MqRjLSW8kY 9yCkgH4+Vj8a
6G5/1q/9c0/9BFVZohNGVyVOQVYdVI5BH0NEZcslJDaurHgF1cvISmcIO3rX ceS5+Ds0uDsE
GPx+0ijxN4KaW5a6sfKhlc5eB2CIx9Y2PAz/AHSQR2zVfd4v/wCEPbwx/YUn 9nseZ/s77sb9
+N/3cZr6KdeniacHFpNSTd3Y8+NOVOTTXQ4XYSa9t8J2clnpNvDICGito42B 7Es8pH4ebj8K
5Xw14LaO5S6vfKmlQ5SBGDop9ZGHBA/ugknvivRoYhDHtyWJJLMerE8kn6mu PNcXTqtQp6pG
2GpOGrJKKKK8c6wooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKAKup/wDI
KvP+uD/+gmvnmvobU/8AkFXn/XB//QTXzzVRJZ9LXP8ArV/65p/6CKhqa5/1 q/8AXNP/AEEV
DUjEZQwIYAg9Qarf2ZYb9/2G23f3vKXP8qtUUDEVQoAUAAdAKWiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigCrqf/IKvP8Arg//AKCa+ea+ htT/AOQVef8A
XB//AEE1881USWfS1z/rV/65p/6CKhqa5/1q/wDXNP8A0EVDUjCiiigYUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRWJa6hrl/FJcWun6ULcXE8MZn1GVHYRSvESVW3YDJ QnGTU+/xH/z4
6H/4M5//AJFosI1KKy9/iP8A58dD/wDBnP8A/ItG/wAR/wDPjof/AIM5/wD5 FosBqUVl7/Ef
/Pjof/gzn/8AkWjf4j/58dD/APBnP/8AItFgNSisvf4j/wCfHQ//AAZz/wDy LRv8R/8APjof
/gzn/wDkWiwGpRWXv8R/8+Oh/wDgzn/+RapWXiG8k8Wt4fvbKzjlWzN15trd vKowyrtIeJOf
mByM/wCBYDX1P/kFXn/XB/8A0E18819Dan/yCrz/AK4P/wCgmvnmqiJn0tc/ 61f+uaf+gioa
muf9av8A1zT/ANBFQ1IwooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB zenpFLpmlxzB
GVtYvyEcjBZbm6ZeCwyQVDDh8FQdoxvXXTR9Mj2eXp1muzbt2wKNu3ZjHHGP Kjx6eWv90Yy9
MZ49JsJAszIurXwk8pWbAa6uVBYKw+Xcy5JDAdSBjeuomqW8mzEd4N+3G6zl HXZjOV4/1i5z
0w2cbGwMQJo+mR7PL06zXZt27YFG3bsxjjjHlR49PLX+6MINI0uFVZdOtEEY BXbAo27dmMcd
vKjx/wBc1/ujCpqlvJsxHeDftxus5R12YzleP9Yuc9MNnGxsCapbybMR3fz7 cbrOUddmM5Xj
/WLnPTDZxsbCdxnLRNLBp9jrLaZoyafO8IS2S02ywo5jWJvM3EMQUh4CjGxc H5BmfwtNba9B
b3kOmaZDZxRRq+23AdpgsZ+QZ+RF8uLGck7EIwFUma30vTw0EYudZaxR1kgs XtXWKJiUK8+W
HwpkU7WYhcNwPLO2xp1vp1lNZy2p1JCltHbFWtZAJlAQIZAU4ZfMHPGPnzwj baVtRM1E0fTI
9nl6dZrs27dsCjbt2Yxxxjyo8enlr/dGBNH0yPZ5enWa7Nu3bAo27dmMccY8 qPHp5a/3RgTV
LeTZiO8G/bjdZyjrsxnK8f6xc56YbONjYE1S3k2YjvBv243Wco67MZyvH+sX OemGzjY2EAJo
+mR7PL06zXZt27YFG3bsxjjjHlR49PLX+6McT4fTy/iTbx7Nm3QANmzZtwYO NuxMfTYuP7o6
Dtk1S3k2YjvBv243Wco67MZyvH+sXOemGzjY2OJ8Pp5fxJt49mzboAGzZs24 MHG3YmPpsXH9
0dA0B3Op/wDIKvP+uD/+gmvnmvobU/8AkFXn/XB//QTXzzTiJn0tc/61f+ua f+gioajutSsV
n2m9twyoqkGVcghQCOtQ/wBp2H/P7bf9/V/xqRlqiqv9p2H/AD+23/f1f8aP 7TsP+f22/wC/
q/40DLVFVf7TsP8An9tv+/q/40f2nYf8/tt/39X/ABoAtUVV/tOw/wCf22/7 +r/jR/adh/z+
23/f1f8AGgC1RVX+07D/AJ/bb/v6v+NH9p2H/P7bf9/V/wAaALVFVf7TsP8A n9tv+/q/40f2
nYf8/tt/39X/ABoAtUVV/tOw/wCf22/7+r/jR/adh/z+23/f1f8AGgC1RVX+ 07D/AJ/bb/v6
v+NH9p2H/P7bf9/V/wAaALVFVf7TsP8An9tv+/q/40f2nYf8/tt/39X/ABoA tUVV/tOw/wCf
22/7+r/jR/adh/z+23/f1f8AGgC1RVX+07D/AJ/bb/v6v+NH9p2H/P7bf9/V /wAaALVFVf7T
sP8An9tv+/q/40f2nYf8/tt/39X/ABoAtUVV/tOw/wCf22/7+r/jR/adh/z+ 23/f1f8AGgC1
RVX+07D/AJ/bb/v6v+NH9p2H/P7bf9/V/wAaALVFVf7TsP8An9tv+/q/40f2 nYf8/tt/39X/
ABoAtUVV/tOw/wCf22/7+r/jR/adh/z+23/f1f8AGgC1RVX+07D/AJ/bb/v6 v+NH9p2H/P7b
f9/V/wAaALVFVf7TsP8An9tv+/q/40f2nYf8/tt/39X/ABoAtUVV/tOw/wCf 22/7+r/jR/ad
h/z+23/f1f8AGgC1RVX+07D/AJ/bb/v6v+NH9p2H/P7bf9/V/wAaALVFVf7T sP8An9tv+/q/
40f2nYf8/tt/39X/ABoAtUVV/tOw/wCf22/7+r/jR/adh/z+23/f1f8AGgDm br4e211dTTf2
9rcSySySiKOePZGXdnYKDGcDczHHvUP/AArW1/6GHXv+/wDF/wDG66z+07D/ AJ/bb/v6v+NH
9p2H/P7bf9/V/wAad2LQ5P8A4Vra/wDQw69/3/i/+N0f8K1tf+hh17/v/F/8 brrP7TsP+f22
/wC/q/40f2nYf8/tt/39X/Gi7DQ5P/hWtr/0MOvf9/4v/jdH/CtbX/oYde/7 /wAX/wAbrrP7
TsP+f22/7+r/AI0f2nYf8/tt/wB/V/xouw0OT/4Vra/9DDr3/f8Ai/8AjdH/ AArW1/6GHXv+
/wDF/wDG66z+07D/AJ/bb/v6v+NH9p2H/P7bf9/V/wAaLsNDk/8AhWtr/wBD Dr3/AH/i/wDj
daGheCrTQdWbUo9R1G7nMDW4+1OjAKWVjjagOcqO/rW5/adh/wA/tt/39X/G j+07D/n9tv8A
v6v+NLUA1P8A5BV5/wBcH/8AQTXzzXvuoahZPpt0iXluzNC4AEqkk4PvXgVV ETPqf/hE/Df/
AEL+lf8AgFH/AIUf8In4b/6F/Sv/AACj/wAK2KKoRj/8In4b/wChf0r/AMAo /wDCj/hE/Df/
AEL+lf8AgFH/AIVsUUAY/wDwifhv/oX9K/8AAKP/AAo/4RPw3/0L+lf+AUf+ FbFFAGP/AMIn
4b/6F/Sv/AKP/Cj/AIRPw3/0L+lf+AUf+FbFFAGP/wAIn4b/AOhf0r/wCj/w o/4RPw3/ANC/
pX/gFH/hWxRQBj/8In4b/wChf0r/AMAo/wDCj/hE/Df/AEL+lf8AgFH/AIVs UUAY/wDwifhv
/oX9K/8AAKP/AAo/4RPw3/0L+lf+AUf+FbFFAGP/AMIn4b/6F/Sv/AKP/Cj/ AIRPw3/0L+lf
+AUf+FbFFAGP/wAIn4b/AOhf0r/wCj/wo/4RPw3/ANC/pX/gFH/hWxRQBj/8 In4b/wChf0r/
AMAo/wDCj/hE/Df/AEL+lf8AgFH/AIVsUUAY/wDwifhv/oX9K/8AAKP/AAo/ 4RPw3/0L+lf+
AUf+FbFFAGP/AMIn4b/6F/Sv/AKP/Cj/AIRPw3/0L+lf+AUf+FbFFAGP/wAI n4b/AOhf0r/w
Cj/wo/4RPw3/ANC/pX/gFH/hWxRQBj/8In4b/wChf0r/AMAo/wDCj/hE/Df/ AEL+lf8AgFH/
AIVsUUAY/wDwifhv/oX9K/8AAKP/AAo/4RPw3/0L+lf+AUf+FbFFAGP/AMIn 4b/6F/Sv/AKP
/Cj/AIRPw3/0L+lf+AUf+FbFFAGP/wAIn4b/AOhf0r/wCj/wo/4RPw3/ANC/ pX/gFH/hWxRQ
Bj/8In4b/wChf0r/AMAo/wDCj/hE/Df/AEL+lf8AgFH/AIVsUUAY/wDwifhv /oX9K/8AAKP/
AAo/4RPw3/0L+lf+AUf+FbFFAGP/AMIn4b/6F/Sv/AKP/Cj/AIRPw3/0L+lf +AUf+FbFFAGP
/wAIn4b/AOhf0r/wCj/wo/4RPw3/ANC/pX/gFH/hWxRQBj/8In4b/wChf0r/ AMAo/wDCj/hE
/Df/AEL+lf8AgFH/AIVsUUAY/wDwifhv/oX9K/8AAKP/AAo/4RPw3/0L+lf+ AUf+FbFFAGP/
AMIn4b/6F/Sv/AKP/Cj/AIRPw3/0L+lf+AUf+FbFFAGP/wAIn4b/AOhf0r/w Cj/wo/4RPw3/
ANC/pX/gFH/hWxRQBj/8In4b/wChf0r/AMAo/wDCj/hE/Df/AEL+lf8AgFH/ AIVsUUAY/wDw
ifhv/oX9K/8AAKP/AAo/4RPw3/0L+lf+AUf+FbFFAGP/AMIn4b/6F/Sv/AKP /Cj/AIRPw3/0
L+lf+AUf+FbFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FAH/2Q==
--------------050901070007090403030904--
Re: Auto completion of return type [message #271678 is a reply to message #271614] Mon, 22 June 2009 11:03 Go to previous message
Originally posted by: mauro.molinari.cardinis.com
G Gev ha scritto:
> will do the trick?
> --Gautam
After writing "someObject.someMethod();" type Ctrl+1 to invoke Quick Fix
and select the option to assign the value to a local variable.
HTH.
Mauro.
Previous Topic:my tomcat-users.xml file
Next Topic:Creating a project from a list of files?
Current Time: Thu Feb 22 23:19:19 GMT 2018
Powered by FUDForum. Page generated in 0.03308 seconds
