Home » Archived » Memory Analyzer (MAT) » OQL Preferences
OQL Preferences [message #2269] Mon, 30 June 2008 17:07 Go to next message
Originally posted by: slto.yahoo.com
In the OQL results window, by default it displays 25 rows at a time. Is
this configurable? I would like to export the entire result set to a
txt, right now it seems to export only the displayed rows so I have to
manually expand many times to see all the rows before I can export
Re: OQL Preferences [message #2299 is a reply to message #2269] Tue, 01 July 2008 06:25 Go to previous messageGo to next message
Found the Expand All option, so that solves my problem
Re: OQL Preferences [message #2328 is a reply to message #2299] Tue, 01 July 2008 08:50 Go to previous message
Andreas Buchen is currently offline Andreas BuchenFriend
you can also export as CSV (which will always export the whole table).
Select the Export button in the tool bar and select CSV. This might be
easier to work with later.
Andreas.
Previous Topic:finding the size of a single object (& more)
Next Topic:Unsupported segment type 254 at position 366,014,124
Current Time: Tue Jan 16 11:55:07 GMT 2018
Powered by FUDForum. Page generated in 0.01506 seconds
