Add Java run button to other perspectives? [message #270787] |
Wed, 13 May 2009 20:08 |
Originally posted by: ddd.asd.com
I have installed BIRT for eclipse. When I switch to the reporting
perspective the Java "Run as..." button disappears. I know it does not make
much sense to run a java application when in the reporting perspective. But
is it somehow possible to add this button anyway to the reporting
perspective so I can run my run configurations even though I am in the
reporting perspective?
Re: Add Java run button to other perspectives? [message #270799 is a reply to message #270796] |
Thu, 14 May 2009 06:32 |
When I open Window -> Customize perspective I get a box with two panes:
Shortcuts and Commands. Neither of these panes contains anything called
ToolBar Visibility.
"Ankur Sharma" <sharma.ankur@gmail.com> wrote in message
news:gugcdm$d31$1@build.eclipse.org...
>> make much sense to run a java application when in the reporting
>> perspective. But is it somehow possible to add this button anyway to the
>> reporting perspective so I can run my run configurations even though I am
>> in the reporting perspective?
> Window -> Customize perspective... -> Toolbar Visibility
> should do the trick for you.
> hth,
> Ankur..
Re: Add Java run button to other perspectives? [message #270811 is a reply to message #270799] |
Thu, 14 May 2009 16:16 |
Originally posted by: wegener.cboenospam.com
Use the Commands tab and select Launch. This should add Run/Debug buttons
to your toolbar.
"mlt" <ddd@asd.com> wrote in message news:gugduv$tn8$1@build.eclipse.org...
> ToolBar Visibility.
the
am
> > hth,
> > Ankur..
Re: Add Java run button to other perspectives? [message #270818 is a reply to message #270811] |
Thu, 14 May 2009 17:51 |
Thanks!
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:guhg4e$r59$1@build.eclipse.org...
> to your toolbar.
>> ToolBar Visibility.
> the
> am
>> > hth,
>> > Ankur..
Re: Add Java run button to other perspectives? [message #270830 is a reply to message #270807] |
Thu, 14 May 2009 18:44 |
Ankur Sharma wrote:
>> panes: Shortcuts and Commands. Neither of these panes contains
>> anything called ToolBar Visibility.
>>>> not make much sense to run a java application when in the reporting
>>>> the reporting perspective so I can run my run configurations even
>>>> though I am in the reporting perspective?
>>> hth,
>>> Ankur..
> My bad. Apologies. I don't have BIRT and assumed the that this will work
> for all the perspectives. Just check if there is something on interest
> in Shortcuts tab. Meanwhile, I will try and get BIRT and check it if its
> possible there.
Ankur,
You're talking about the 3.5 version of the Customize Perspective
dialog; I suspect mlt is using 3.4, which is significantly different.
mlt, Dave's advice should be exactly what you need for Eclipse 3.4
(Ganymede), while Ankur's is for 3.5 (Galileo).
Hope this helps,
Eric
FUDForum. Page generated in 0.08899 seconds
