Home » Newcomers » Newcomers » JVM terminated. Exit code=1
JVM terminated. Exit code=1 [message #270472] Thu, 23 April 2009 01:13 Go to next message
Yamuda is currently offline YamudaFriend
I don't know much about eclipse, but it is the program we are using in my
class, and I need to get it to work on my computer, so I can work on the
assignments from home...
So pretty much, I am a noob..
I was trying Eclipse 3.4.2 but that kept crashing upon opening it, and so
did 3.3, then 3.2 I got this message below... I had 3.4.2 working before,
but now, won't even open...
thanks for all the help
C:\Windows\system32\javaw.exe
-Xms40m
-Xmx256m
-jar C:\Users\**** ****\Desktop\eclipse.startup.jar
-os win32
-ws win32
-arch x86
-launcher C:\Users\**** ****\Desktop\eclipse\eclipse.ece
-name Eclipse
-showsplash 600
-exitdata ea4_ec
-vm C:\Windows\system32.javaw.exe
-vmargs
-Xms40m
-Xmx256m
-jar C:\Users\**** ****\Desktop\eclipse\startup.jar
Re: JVM terminated. Exit code=1 [message #270474 is a reply to message #270472] Thu, 23 April 2009 05:21 Go to previous messageGo to next message
Ankur Sharma is currently offline Ankur SharmaFriend
Member
> my class, and I need to get it to work on my computer, so I can work on
> the assignments from home...
> so did 3.3, then 3.2 I got this message below... I had 3.4.2 working
> before, but now, won't even open...
Do you have a JRE/JDK installed?
http://www.eclipse.org/downloads/moreinfo/jre.php
http://www.eclipse.org/downloads/moreinfo/java.php
hth,
Ankur..
Re: JVM terminated. Exit code=1 [message #270476 is a reply to message #270474] Thu, 23 April 2009 07:28 Go to previous messageGo to next message
Alright, thanks, all fixed, what a nightmare :[
Re: JVM terminated. Exit code=1 [message #270480 is a reply to message #270472] Thu, 23 April 2009 15:23 Go to previous messageGo to next message
It is strongly recommended that you specify the full path to your java
executable using eclipse.ini. See here: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
> -Xms40m
> -Xmx256m
> -os win32
> -ws win32
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata ea4_ec
> -vmargs
> -Xms40m
> -Xmx256m
Re: JVM terminated. Exit code=13 [message #536113 is a reply to message #270472] Thu, 27 May 2010 06:51 Go to previous messageGo to next message
Frankie  is currently offline Frankie Friend
I'm having the same issue. I've tried manually starting Eclipse with a JVM by using -vm. Still gives me an error.
Please help. Heres my error message.
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Users\Frankie\Downloads\eclipse-SDK-3.2 .3-win32\eclipse\plugins/org.eclipse.equinox.launcher_1.0.20 1.R35x_v20090715.jar
-os win32
-ws win32
-arch x86
-showsplash
C:\Users\Frankie\Downloads\eclipse-SDK-3.5.2-win32\eclipse\\ plugins\org.eclipse.platform_3.3.202.v201002111343\splash.bm p
-launcher
C:\Frankie\Downloads\eclipse-SDK-3.5.2-win32\eclipse\eclipse .exe
-name Eclipse
--launcher.library
C:\Users\Frankie\Downloads\eclipse-SDK-3.5.2win32\eclipse\pl ugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v 20090519\eclipse_1206.dll
-startup
C:\Users\Frankie\Downloads\eclipse-SKD-3.5.2-win32\eclispe\p lugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.j ar
-vm C:\Program Files\Java\jre6\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx256m
-XX:MaxPermSize=256
-Djava.class.path=C:Users\Frankie\Downloads\eclipse-SDK-3.5. 2-win32\eclipse\plugins/org.eclipse.equinox.launcher_1.0.201 .R35x_v20090715.jar
Re: JVM terminated. Exit code=13 [message #538434 is a reply to message #536113] Mon, 07 June 2010 15:56 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
See http://wiki.eclipse.org/Eclipse.ini
> -Xms40m
> -Xmx256m
> -os win32
> -ws win32
> -arch x86
> -showsplash
> -launcher
> -name Eclipse
> --launcher.library
> -startup
> -vmargs
> -Xms40m
> -Xmx256m
> -XX:MaxPermSize=256
> .R35x_v20090715.jar
Re: JVM terminated. Exit code=13 [message #632167 is a reply to message #538434] Mon, 11 October 2010 21:14 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I am getting a similiar error and added the path
C:\Program Files\Java\jdk1.6.0_21\bin\javaw.exe
to the Eclipse.ini as instructed on the website you gave.
But when i open the eclipse i still get the same message.
any other suggestion???
maybe i am not going about it correctly because the file opens in notepad and the commands are all on a single line? so i added it to the location shown?
JVM reminated. Exit code=-1
-XX:MaxPermSIze=256m
-Djave.class.path=C:\User\Colin\Documents\Eclipse\plugins/or g.eclipse.equinox.launcher_1.0.200.v20090520.jar
-os win32
-ws win32
-arch x86
-showsplash
-C:\Users\Colin\Documents\Eclipse\\plugins\org.eclipse.platf orm_3.3.200.v200906111540\splash.bmp
-launcher C:\Users\Colin\Documents\Eclipse\eclipse.exe
-name eclipse
--launcher.library
C:\users\Colin|documents\Eclipse\plugins/org.eclipse.equinox .launcher_1.0.200.v20090520.jar
-product org.eclipse.epp.package.jee.producy
-vmC:\Program Files\Java\jdk1.6.0_21\bin\javaw.exe-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-vm C:|PRogram Files|Java\jdk1.6.0_21\bin\..\jre\bin\server\jvm.dll
-vmargs
-Djava.class.path=C:\User\colin\Documents\Eclipse\plugins/or g.eclipse.equinox.launcher_1.0.200.V20090520.jar
Re: JVM terminated. Exit code=13 [message #632168 is a reply to message #632167] Mon, 11 October 2010 21:29 Go to previous messageGo to next message
Could the issue be tied to the fact i have installed JDK 6 for windows x64 and downloaded and unzipped eclipse 3.5 for windows 32 at
http://www.eclipse.org/downloads/packages/release/galileo/sr 2
i didnt see a eclipse IDE for javvaEE developers in windows 32 bit?
Re: JVM terminated. Exit code=13 [message #632171 is a reply to message #632167] Mon, 11 October 2010 21:27 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> location shown?
> -os win32
> -ws win32
> -arch x86
> -showsplash
> -name eclipse
> --launcher.library
> -Xms40m
> -Xmx512m
> -vmargs
Yes, if they're on the same line in Notepad, they're probably wrong. You
should have:
-vm
-vmargs
Re: JVM terminated. Exit code=13 [message #632172 is a reply to message #632168] Mon, 11 October 2010 21:46 Go to previous message
You must ensure identical bittedness for both the JDK and Eclipse.
Previous Topic:Getting wizard selection object null.
Next Topic:Showing new search results in the same view.
Current Time: Fri Jun 22 00:15:43 GMT 2018
Powered by FUDForum. Page generated in 0.03636 seconds
