Home » Eclipse Projects » Eclipse Platform » Compiler Setting: Unnecessary Exception Declaration
Compiler Setting: Unnecessary Exception Declaration [message #269310] Mon, 30 August 2004 19:31 Go to next message
Originally posted by: jay.kurant.com
Not sure if this is the correct newsgroup, so please correct me if it is
not.
Given the following classes:
public class A {
public void doSomething() throws IOException {
// nothing to do here
public class B extends A {
throw new IOException("I'm not doing anything!");
I enabled the compiler setting (Java | Compiler | Unused Code |
Unnecessary declaration of thrown checked exceptions) to be a warning. I
then get that A.doSomething() unnecessarily throws an IOException, as
expected. I then checked the box under the above compiler option, "Check
overriding and implementing methods". I expected the above warning to go
away, but it didn't.
I checked the archives and bug database about this, but I can only find
where the checkbox was added since having the functionality to check
overridding classes as the default could be costly (if I understand the
checkbox functionality correctly). I also could not find any documentation
in the help about this setting or the checkbox.
Any help on straighten me out on the purpose of this checkbox or why I am
still getting the warning would be greatly appreciated!
Platform: Eclipse 3.0
JDK: Sun, 1.4.2_02-b03
Re: Compiler Setting: Unnecessary Exception Declaration [message #269433 is a reply to message #269310] Tue, 31 August 2004 08:21 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
>not.
The correct one is eclipse.tools.jdt.
>public class A {
It's the other way around: the checkbox affects B not A.
Dani
Re: Compiler Setting: Unnecessary Exception Declaration [message #269587 is a reply to message #269433] Tue, 31 August 2004 18:32 Go to previous messageGo to next message
Daniel Megert wrote:
> >public class A {
Ok, so if B.doSomething() above did nothing and I uncheck the box, I only
get the warning for A.doSomething(). If I check the box, I get both
warnings. But wouldn't B get checked with the the original setting since
the concept would be the same if checking A or B? Why is B immune from the
check since it is simply overriding the method? It doesn't call the parent
nor does it throw an exception!
So to linger on this topic, I am just trying to understand. Also, there
seems to be no way to get rid of the warning for class A (due to having to
check all derived classes), correct?
Thanks for your help!
Re: Compiler Setting: Unnecessary Exception Declaration [message #270016 is a reply to message #269587] Fri, 03 September 2004 13:43 Go to previous message
>>>public class A {
It's not about checking derived classes but yes, you can't get rid of
that warning. That's the reason why we set this setting to 'ignore'. I
just filed a feature request to improve this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=73244
Dani
Previous Topic:Problem with "Resource move/delete hooks"
Next Topic:moving views between folders
Current Time: Mon May 21 07:19:30 GMT 2018
Powered by FUDForum. Page generated in 0.02082 seconds
