| RCP branding problem [message #268476] |
Tue, 24 August 2004 14:53  |
Originally posted by: nomelody.gmx.net
Hi I am developing an RCP application with Eclipse 3.0 and I am having
trouble with the branding. I have added the following to my plugin.xml
file to change some things like icons/about text... however it does nothing
<extension id="myproduct" point="org.eclipse.core.runtime.products">
<product name="My RPC Application"
application="com.steve.RcpApplication">
<property name="appName" value="My RPC Application"/>
<property name="windowImages" value="icons/product.gif"/>
<property name="aboutText" value="About My RPC Application"/>
<property name="aboutImage" value="icons/product.gif"/>
</product>
</extension>
where "com.steve.RcpApplication" implements IPlatformRunnable. can anybody
point me in the right direction please. I am developing it as an plugin
and not a feature but it shouldnt matter if I add to the
"org.eclipse.core.runtime.products" extension, right? Cheers for any help.
Steve
| Re: RCP branding problem [message #268506 is a reply to message #268476] |
Tue, 24 August 2004 22:46   |
Originally posted by: manahan.NOSPAM.ca.ibm.com
Did you run eclipse with either -Declipse.product=<pluginid>.myproduct
or set eclipse.product in the configuration/config.ini file?
Peter
> </product>
> </extension>
> Steve
| Re: RCP branding problem [message #268596 is a reply to message #268506] |
Wed, 25 August 2004 05:58   |
Thanks Peter, thats the solution allright, I just needed to set up the
config.ini file correctly, cheers :)
Steve
> Peter
> > </product>
> > </extension>
> > Steve
| Re: RCP branding problem [message #268643 is a reply to message #268628] |
Wed, 25 August 2004 08:38   |
I tryed setting -Dosgi.splashPath=platform:/base/plugins/<mypluginid> in
the run configurator but no joy. If i get it working Ill mail you.
Steve
> > Peter
> Btw.: Do you know whether it is possible to envoke the splash screen of
> an RCP by starting it via the Eclipse run configurator?
> I do get the splash screen in my exported product (where the
> osgi.splashPath is correctly set), but currently I don't know how to
> get the same effect in the program started by Eclipse itself.
> Thanks in advance,
> Daniel Krügler
| Re: RCP branding problem [message #268751 is a reply to message #268476] |
Wed, 25 August 2004 21:22   |
Originally posted by: pascal.ibm.canada
You can find info about branding a product here:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/docs/branding/BrandingYourApplication.html
PaScaL
> </product>
> </extension>
> Steve
| Re: RCP branding problem [message #268804 is a reply to message #268782] |
Thu, 26 August 2004 08:08  |
The osgi.splashPath does not work in selfhost (because Main which does
not know a lot, only looks for the plugins in the plugin folder).
It could be good if you opened a bug report against platform runtime.
PaScaL
> Hello Pascal Rapicault,
> Thanks for that nicely written document!
> One question remains: In the section "Replacing the splash screen" it says
> The splash screen to be displayed is controlled by system properties
> that can either be passed as vm arguments or added to the config.ini
> file that we modified previously. The two properties are:
> * osgi.splashLocation: full path to the splash screen in the file
> system. For example
> c:/eclipse/plugins/org.eclipse.ui.examples.rcp.browser/splas h.bmp;
> * osgi.splashPath: comma separated list of URL that will be searched for
> the splash screen. Only "file:" and "platform:" URLs are supported. For
> example platform:/base/plugins/org.eclipse.ui.examples.rcp.browser/. The
> entries will be searched until a file called splash.bmp is found.
> My product branding concerning the splash screen does work in the
> deployed version, but not the version started by the Eclipse run
> configurator (where the configuration is set to "Run as product").
> Lets say the plugin providing the product extension is named
> com.example.ui, I added the the VM argument
> -Dosgi.splashPath=platform:/base/plugins/com.example.ui
> where the splash.bmp is located in my workspace/com.example.ui
> directory, but it doesn't work (Btw: I also tried
> -Dosgi.splashPath=platform:/base/plugins/com.example.ui/
> Please note that the remaining product features like windowImages and
> in the **deployed** version (via its config.ini entry) **does** work.
> Is that a bug or what is my error here??
> Thanks in advance,
> Daniel Krügler
FUDForum. Page generated in 0.01649 seconds
