| Installing IDE for Java Developers [message #268221] |
Fri, 30 January 2009 10:51  |
Jerry Carlson Messages: 2 Registered: July 2009 |
Junior Member |
I already have eclipse installed on my computer, it was installed when
Dialog Designer from Avaya was installed. But now I would like to install
the IDE for Java Developers. I am unable to use the update facility in
Eclipse because of the firewall settings where I work. I can download it
from the download page, so how do I install it.
| Re: Installing IDE for Java Developers [message #268223 is a reply to message #268221] |
Fri, 30 January 2009 11:18   |
> install the IDE for Java Developers. I am unable to use the update
> facility in Eclipse because of the firewall settings where I work. I can
> download it from the download page, so how do I install it.
Jerry,
If your machine at work can at least go through proxy (ask your network
administrator), this guide should help you to configure Eclipse to use
the proxy:
http://www.drgarbage.com/eclipse-proxy-configuration-guide.h tml
Peter
Peter Palaga
| Re: Installing IDE for Java Developers [message #268233 is a reply to message #268221] |
Fri, 30 January 2009 12:54  |
Installing Eclipse (on Windows at least) is just a matter of unzipping
it and running the eclipse.exe executable. It will prompt you for a
location to create a workspace in, which you might want to change from
the default.
The only other step that is hihgly recommended before running Eclipse is
to tell it specifically what JVM to run in (a JDK, as opposed to a JRE,
is best if you're doing Java development). See this wiki page for the
details: http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
FUDForum. Page generated in 0.01729 seconds
