| Disabling The RESIZING of a WINDOW [message #267777] |
Fri, 16 January 2009 08:51  |
adithya Messages: 77 Registered: July 2009 |
Member |
Hi..I am developing an editor using SWT/JFace and I am specifying the size
of the window using
getShell.setBounds(200,100,400,500);
getShell().setMaximized(false);
parent.pack();
but its not working.
I don't want the user to maximize the window i.e. I want the size to be
what I have decided..How do I do this??
| Re: Disabling The RESIZING of a WINDOW [message #267805 is a reply to message #267777] |
Fri, 16 January 2009 16:17   |
> size of the window using
> parent.pack();
When you create the shell, what style bits (int argument) are you
passing to the constructor?
See the class Javadoc under the title "Styles:" for what bits can be
used and then look in the SWT class for their meanings.
Hope this helps,
Eric
| Re: Disabling The RESIZING of a WINDOW [message #267828 is a reply to message #267809] |
Mon, 19 January 2009 16:14   |
On 1/17/2009 6:42 AM, adithya wrote:
> This is what i have done..
> public class EditorTry7 extends ApplicationWindow
> public EditorTry7()
> super(null);
<snipped more code>
> I dint get any option as Styles,as there is no argument in "open()"
> method..
> What should i do as to disable resizing.
Look at your call to the super constructor; do you know why you're
passing null? Do you know the ramifications of doing so, instead of
passing in a Shell object?
Also look at the methods that ApplicationWindow inherits from Window,
specifically getShellStyle()/setShellStyle().
A little reading of the Javadoc and the source code will go a long way.
Eric
FUDForum. Page generated in 0.01548 seconds
