Home » Newcomers » Newcomers » How do I add command-line arguments when running as Java app?
How do I add command-line arguments when running as Java app? [message #267035] Thu, 11 December 2008 17:58 Go to next message
D. Alvarado is currently offline D. AlvaradoFriend
Member
I'm using Eclipse 3.4 on WinXP. I want to run a file as a Java
application, so I right-click the file, select "Run As", and select "Java
Application". However at no point in the process am I asked to specify
command line arguments and so my Java app fails with
ArrayIndexOutOfBoundsExceptions b/c "args[0]" has no value.
How do I specify command-line arguments when running Java apps in Eclipse?
Thanks, - Dave
Re: How do I add command-line arguments when running as Java app? [message #267037 is a reply to message #267035] Thu, 11 December 2008 18:17 Go to previous messageGo to next message
Charlie Kelly is currently offline Charlie KellyFriend
Hi Dave,
Run->Run Configuration
select your launch configuration
go to "Arguments" tab
Supply your arguments as "VM arguments"
Charlie
D. Alvarado wrote:
> "Java Application". However at no point in the process am I asked to
> specify command line arguments and so my Java app fails with
> Thanks, - Dave
Re: How do I add command-line arguments when running as Java app? [message #267055 is a reply to message #267037] Fri, 12 December 2008 05:52 Go to previous message
Remy Suen is currently offline Remy SuenFriend
Actually, I think Dave wants "Program arguments" since he's referring to
args[0] and not about VM arguments.
The FAQ link below has images to help guide you.
http://wiki.eclipse.org/Graphical_Eclipse_FAQs#How_do_I_add_ arguments_to_the_Java_program_I_am_running.3F
Remy
> D. Alvarado wrote:
>> Eclipse?
>> Thanks, - Dave
Previous Topic:Toggle Line Breakpoint (epic)
Next Topic:open Perspective from Intro screen?
Current Time: Sun Feb 25 22:26:15 GMT 2018
Powered by FUDForum. Page generated in 0.02985 seconds
