| eclipse doesn't autocomplete constructors [message #266343] |
Sun, 16 November 2008 14:08  |
Originally posted by: mailpgrupos.netcabo.pt
I tried this with eclipse 3.2 and 3.4, and the result is the same:
1. Write
Scanner r = new Scanner(); // (or any other class)
2. Put the cursor on the right paren.
3. Press ctrl+space to call content assist. A list of Scanner constructors
appears.
4. Press down arrow to select the one that suits my needs and enter to
select it.
Expected results: eclipse should replace the empty parens with the arguments
of the selected constructor sorounded by parens.
Actual results: eclipse mantains the empty parens (ddoesn't fill with the
constructor arguments).
With methods, eclipse autocompletes them, but not with constructors.
Is this an important bug, or am I missing something? If it's a bug, what is
its url (I don't believe people haven't discovered this before, but I don't
find references to this bug). In fact, I think it's an important feature to
correct and, with it, eclipse will be the best.
Best regards
S
FUDForum. Page generated in 0.01377 seconds
