Home » Newcomers » Newcomers » No repository found
No repository found [message #265923] Tue, 28 October 2008 15:58 Go to next message
Mario Michetti is currently offline Mario Michetti
Hi everyone, just installed Eclipse Classic 3.4 yesterday. Tried Help >
Software Updates > Available Software. I get:
No repository found at http://download.eclipse.org/releases/ganymede
Error reading update site http://download.eclipse.org/releases/ganymede.
Connection timed out: connect
Yet I can navigate to the page and view the contents of the page, like:
<?xml version="1.0" encoding="UTF-8" ?>
- <site
mirrorsURL=" http://www.eclipse.org/downloads/download.php?file=/releases /ganymede/site.xml&format=xml&protocol=http"
pack200="true" digestURL="http://download.eclipse.org/releases/ganymede/">
<description url="http://www.eclipse.org/ganymede/">This Ganymede
Discovery Site contains a number of Eclipse based projects released
simultaneously, June 2008.</description>
etc,etc.
I googled
«No repository found at http://download.eclipse.org/releases/ganymede»
and got 7 useless hits.
Am I the lone soul who can`t get this to work?
Thanks in advance
Mario
Re: No repository found [message #265929 is a reply to message #265923] Wed, 29 October 2008 04:37 Go to previous messageGo to next message
Owen Rees is currently offline Owen Rees
Member
mario.michetti@intria.com (Mario Michetti) writes:
> <?xml version="1.0" encoding="UTF-8" ?> - <site
> pack200="true"
I assume you mean you used a web browser to get that - if so, is it
configured to use a web proxy? If your browser is using a proxy then
you need to configure Eclipse to use one too (see the General/Network
Connections preference page).
If your proxy has a cache you may get some further problems with that
until release 3.4.2 which will include a fix for bug 249990:
249990: [transport] p2 fail to see new changes when behind proxy
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=249990>
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: No repository found [message #265987 is a reply to message #265929] Fri, 31 October 2008 12:00 Go to previous messageGo to next message
Thanks Owen, I had forgotten about the proxy. Configured Eclipse as per
your instructions and Updates now work.
But I have another question. Where can I find a GUI builder for Java? I
didn't find it in the Ganymede repository.
Thanks again,
Mario
Re: No repository found [message #266018 is a reply to message #265987] Mon, 03 November 2008 10:16 Go to previous messageGo to next message
Eclipse User
Eclipse.org hosts the VisualEditor project
(http://wiki.eclipse.org/VE/Update) but it is not really maintained any
more.
I use the commercial product, WindowBuilder Pro
(http://www.windowbuilderpro.com/)
Hope this helps,
Eric
Re: No repository found [message #266022 is a reply to message #266018] Mon, 03 November 2008 15:14 Go to previous messageGo to next message
Thanks Again, I've done some research. Seems like commercial products or
Netbeans is the choice for GUIs. It's kind of funny coming from a VS
background.
Mario
Re: No repository found [message #266037 is a reply to message #266022] Tue, 04 November 2008 09:48 Go to previous messageGo to next message
Eclipse User
> background.
Really, it's funny? So you don't consider VS a commercial product?
Eric
Re: No repository found [message #271169 is a reply to message #265923] Wed, 27 May 2009 14:43 Go to previous messageGo to next message
gwt.newbee is currently offline gwt.newbee
I am also facing exactly same problem!!
Did u find a solution to the problem? Please let me know.
Thanks!!
Re: No repository found [message #271171 is a reply to message #265923] Wed, 27 May 2009 14:45 Go to previous messageGo to next message
Hi!
I am also facing exactly the same problem as Mario! Did anyone get a
solution? Please let me know.
Thanks!!
> - <site
> etc,etc.
> I googled
> Thanks in advance
> Mario
Re: No repository found [message #271173 is a reply to message #265923] Wed, 27 May 2009 14:51 Go to previous messageGo to next message
> - <site
> etc,etc.
> I googled
> Thanks in advance
> Mario
Did anyone get a solution for this?? I am facing exactly the same problem!!
Please do let me know!
thanks
Re: No repository found [message #271203 is a reply to message #271173] Thu, 28 May 2009 05:36 Go to previous message
Eclipse User
Eclipse has its own HTTP proxy settings. Please check them out.
"HTTP proxy" settings are not standardized. Almost each program needs to
be told separately.
Yes, on Unix, some programs use an environment variable. Yes, on Windows
some programs read the proxy settings for IE from the registry.
No, both ways are not "standard" for _all_ programs.
Previous Topic:default proxy setup in plugin_customization.ini
Next Topic:bracketing problem
Current Time: Wed May 22 02:18:40 EDT 2013
Powered by FUDForum. Page generated in 0.02320 seconds
