| Eclipse Ganymede 3.4 - org.eclipse.swt.SWTException: Graphic is disposed [message #264160] |
Thu, 11 September 2008 15:03 |
suskshma Messages: 1 Registered: July 2009 |
Junior Member |
I am running Eclipse 3.4 on Windows XP SP2.
I created a simple project and right clicked on source --> 'Debug As'-->
Java Application.
I got the 'Open Progress Monitor' Error.
I got similar errors when I tried to create a new folder under my project
or delete an existing folder under my project.
I got same results when I launched eclipse from command prompt pointing to
JDK1.6.07
I even installed 3.3.2, but got similar results.
Your help is deeply appreciated.
Dump of Error.log
!SESSION 2008-09-11 10:31:54.703
eclipse.buildId=I20080617-2000
java.version=1.6.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2008-09-11 10:35:01.984
!MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2008-09-11 10:35:01.984
!MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
!ENTRY org.eclipse.ui 4 0 2008-09-11 10:43:58.281
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.graphics.Image.setBackground(Image.java:2060 )
org.eclipse.jface.dialogs.IconAndMessageDialog.createMessage Area(IconAndMessageDialog.java:80)
org.eclipse.jface.dialogs.ProgressMonitorDialog.createDialog Area(ProgressMonitorDialog.java:443)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.c reateDialogArea(ProgressMonitorJobsDialog.java:79)
org.eclipse.jface.dialogs.IconAndMessageDialog.createDialogA ndButtonArea(IconAndMessageDialog.java:212)
org.eclipse.jface.dialogs.IconAndMessageDialog.createContent s(IconAndMessageDialog.java:191)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
org.eclipse.jface.dialogs.ProgressMonitorDialog.aboutToRun(P rogressMonitorDialog.java:581)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:504)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
org.eclipse.ui.internal.progress.ProgressManager$3.run(Progr essManager.java:977)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:1012)
org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:987)
org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1195)
org.eclipse.jdt.internal.debug.ui.launcher.MainMethodSearchE ngine.searchMainMethods(MainMethodSearchEngine.java:163)
org.eclipse.jdt.debug.ui.launchConfigurations.JavaApplicatio nLaunchShortcut.findTypes(JavaApplicationLaunchShortcut.java :127)
org.eclipse.jdt.debug.ui.launchConfigurations.JavaLaunchShor tcut.searchAndLaunch(JavaLaunchShortcut.java:112)
org.eclipse.jdt.debug.ui.launchConfigurations.JavaLaunchShor tcut.launch(JavaLaunchShortcut.java:246)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchSho rtcutExtension.launch(LaunchShortcutExtension.java:434)
org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.r un(LaunchShortcutAction.java:73)
org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.r unWithEvent(LaunchShortcutAction.java:121)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
org.eclipse.jface.action.ActionContributionItem$9.handleEven t(ActionContributionItem.java:1283)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
FUDForum. Page generated in 0.01586 seconds
