Home » Eclipse Projects » BIRT » Library items on MasterPage and relative resource path setting
Library items on MasterPage and relative resource path setting [message #263870] Wed, 02 January 2008 16:30 Go to next message
Originally posted by: xpanto00-birt.yahoo.com
I have a report getting some items from a library (grid, label, and data
items), to be shown in a master page.
i set the web.xml BIRT_RESOURCE_PATH to point to a folder like this
<context-param>
<param-name>BIRT_RESOURCE_PATH</param-name>
<param-value>/resources</param-value>
</context-param>
and put the library file on that folder.
when i click the Preview button everything renders, even if some items are
from the library, but deployed they won't: they will only render when i
set a full path for param __resourceFolder and pointing to my workspace,
not deploy path.
tried to put library anywhere, project root, root/resources, even in the
same folder report is, and nothing happens...
i definitely do not want to use just birt_home to put my resources into,
neither use a fixed path (i'm working on a web project)
and also i'd like to separate them (resources/libraries, resources/js,
resources/whatever...).
So, can library items be rendered using a relative path? or is there a
workaround for re-using items on different reports?
Thanks in advice for your help.
PD: using BIRT 2.2.1 and birt-viewer webproject for deploy
Re: Library items on MasterPage and relative resource path setting [message #263952 is a reply to message #263870] Fri, 04 January 2008 17:33 Go to previous messageGo to next message
Jonathan,
If you are using the BIRT web project make sure your have the resources
folder created under WebContent. If you are developing in the same
workspace change your resource folder for the designer to point to this
same location ( it is in the options).
In the report check the libraries setting:
<list-property name="libraries">
<structure>
<property name="fileName">testlib.rptlibrary</property>
<property name="namespace">testlib</property>
</structure>
the filename property should be relative to your resources folder.
Jason
> <context-param>
> </context-param>
> are from the library, but deployed they won't: they will only render
> when i set a full path for param __resourceFolder and pointing to my
> workspace, not deploy path.
Re: Library items on MasterPage and relative resource path setting [message #263972 is a reply to message #263952] Mon, 07 January 2008 16:29 Go to previous messageGo to next message
Thanks Jason for your reply. Now i'm working fine with it, resources are
all linked correctly.
But my other projects are now _only_ poiting to those resources that i set
in the Eclipse Preferences.
Suppose that i have project 1 and project 2, both running different birt's
and in any way related one to another.
I set the Resources Setting to point to my resource folder in project 1.
It works fine, i see all resources.
But now, project 2 allows me to select only the resources from project 1!!
Can this Setting be project-dependent?
Re: Library items on MasterPage and relative resource path setting [message #264067 is a reply to message #263972] Mon, 07 January 2008 23:24 Go to previous messageGo to next message
Jonathan,
Can't you set the resource folder and then create sub directories for
each project?
Jason
> set in the Eclipse Preferences.
> birt's and in any way related one to another.
Re: Library items on MasterPage and relative resource path setting [message #264144 is a reply to message #264067] Tue, 08 January 2008 16:37 Go to previous message
That would be a nice workaround, but some resources cannot be included in
the deploy package for, let's say, a specific client, don't you think?.
Since i have just started working with birt i canĊ½t give you a right
answer, but i'll give a try on your project sub directory alternative and
see how it works.
Thanks!
Previous Topic:Strange behaviour with mysql and BIRT data types
Next Topic:Expand/Collapse Report Group
Current Time: Mon Apr 23 02:15:11 GMT 2018
Powered by FUDForum. Page generated in 0.01667 seconds
