Home » Newcomers » Newcomers » resources not copied when project is build
resources not copied when project is build [message #263671] Tue, 26 August 2008 12:07 Go to next message
Originally posted by: phaluz.svt.cz
hello
in one of projects i am working on, there are some resources (e.g. .xml or
properties files) in source folders. when i build this project, these
files are not copied into output folder. other projects' build is without
problems. i am sure i didn't change any settings. any hints, what might be
wrong?
thanks, petr
Re: resources not copied when project is build [message #263677 is a reply to message #263671] Tue, 26 August 2008 12:12 Go to previous messageGo to next message
Originally posted by: krzysztof.daniel.gmail.com
Could you tell what kind of a project it is?
Have you checked the error log?
On Tue, 2008-08-26 at 12:07 +0000, PetrH wrote:
> hello
> wrong?
> thanks, petr
Re: resources not copied when project is build [message #263686 is a reply to message #263677] Tue, 26 August 2008 12:28 Go to previous messageGo to next message
it is an AspectJ project. i have checked the log, but i don't see anything
suspicious.
>> hello
>> wrong?
>> thanks, petr
Re: resources not copied when project is build [message #263696 is a reply to message #263671] Tue, 26 August 2008 14:13 Go to previous messageGo to next message
PetrH wrote:
> hello
> or properties files) in source folders. when i build this project, these
> without problems. i am sure i didn't change any settings. any hints,
> what might be wrong?
Look at the project Properties, under Java Compiler > Buliding and make
sure your workspace preferences are not overridden there. Specifically,
check the Filtered Resources setting.
Also, make sure the project is actually building; if it has Build Path
problems they will be reported on the Properties dialog, Java Build Path
section.
Hope this helps,
Eric
Re: resources not copied when project is build [message #263752 is a reply to message #263696] Wed, 27 August 2008 09:25 Go to previous messageGo to next message
Petr is currently offline PetrFriend
i have checked and am sure, that preferences are not overridden. even
global settings doesn't filter needed resources. the project is building -
if i manually remove class files, they reappear after build and properties
dialog reports no problems.
> section.
> Hope this helps,
> Eric
Re: resources not copied when project is build [message #263797 is a reply to message #263671] Thu, 28 August 2008 07:47 Go to previous message
everything started to work ok. i don't know how, i don't know why, but
resources are copying once again. again - i didn't change any settings.
nonetheless i thank people who responded and tried to help.
Previous Topic:Explicitly opening the tabbed property view
Next Topic:How to update eclipse instead of eclipse plugins?
Current Time: Thu Jan 18 14:15:26 GMT 2018
Powered by FUDForum. Page generated in 0.04853 seconds
