Home » Newcomers » Newcomers » Persist Getter/Setter Insertion Point
Persist Getter/Setter Insertion Point [message #263107] Wed, 13 August 2008 21:35 Go to next message
Originally posted by: nowhere.a.com
I just installed 3.4
The Generate Getter and Setter Insertion Point does not persist between
calls. I prefer "Last Member", but now this choice always changes.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263132 is a reply to message #263107] Thu, 14 August 2008 07:18 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
> between calls. I prefer "Last Member", but now this choice always
> changes.
This works for me i.e. it keeps my previous settings.
Dani
Re: Persist Getter/Setter Insertion Point [message #263146 is a reply to message #263132] Thu, 14 August 2008 14:42 Go to previous messageGo to next message
And in previous versions it did that for me. Now it always wants to put
it right after whichever field/method I happen to rest the cursor on.
So I constantly need to scroll the list to the top entry - 1 to get
Last Member.
I could not find any property for this, so it must be built in.
Actully I use a fair number of inner/nested classes. I wish there was
an option to place the get/set as the last member BEFORE a class
declaration.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263155 is a reply to message #263146] Thu, 14 August 2008 16:11 Go to previous messageGo to next message
>>> changes.
> put it right after whichever field/method I happen to rest the cursor on.
> Last Member.
Please file a bug with steps to reproduce against JDT UI.
Dani
> declaration.
Re: Persist Getter/Setter Insertion Point [message #263157 is a reply to message #263155] Thu, 14 August 2008 17:59 Go to previous messageGo to next message
>> And in previous versions it did that for me. Now it always wants to put it
>> So I constantly need to scroll the list to the top entry - 1 to get Last
>> Member.
Not sure I could. From your comments it works, yet mine does not. That
would make it an installation specific bug. I did have some problems
getting Eclipse EE installed and configured (my comments in
eclipse.webtools). So to repoduce this I would guess you would need to
start with my previous environment, and go through the steps I took.
I don't even think I can remember them all.
It sounds like I have a slightly corrupted properties file somewhere
which is not "taking" the setting.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263377 is a reply to message #263157] Mon, 18 August 2008 21:44 Go to previous messageGo to next message
>>> Member.
I'm having the same problem, did you ever come up with a fix? Or a bug
report?
Thanks!
Re: Persist Getter/Setter Insertion Point [message #263389 is a reply to message #263377] Tue, 19 August 2008 10:33 Go to previous messageGo to next message
>>>>>> changes.
>>>> cursor on.
>>>> Last Member.
> bug report?
No bug and hence no fix.
Dani
> Thanks!
Re: Persist Getter/Setter Insertion Point [message #263419 is a reply to message #263377] Tue, 19 August 2008 22:35 Go to previous messageGo to next message
>>>> Member.
> report?
I need to switch my email over to where I am now, so I will create a
bug tommorrow.
However I also have another problem in that the column widths of the
Problem view are not being persisted. This may be related. How are your
column widths?
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263421 is a reply to message #263146] Tue, 19 August 2008 22:48 Go to previous messageGo to next message
Wojtek wrote :
> Actully I use a fair number of inner/nested classes. I wish there was an
> option to place the get/set as the last member BEFORE a class declaration.
If I hover over a new field in a class (one which I just typed in), I
get a quick fix "create getter and setter". This getter/setter creator
by default wants to place the new methods after the last method, yet
before the class.
I opened an enhancement bug for this behaviour:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=160344
Yet the quick fix has that already done.
Wojtek :-)
Re: Persist Getter/Setter Insertion Point [message #263430 is a reply to message #263419] Wed, 20 August 2008 02:58 Go to previous messageGo to next message
Dobes Vandermeer is currently offline Dobes VandermeerFriend
>>>>>>> changes.
>>>>> cursor on.
>>>>> Last Member.
>> report?
> I need to switch my email over to where I am now, so I will create a bug
> tommorrow.
> column widths?
I haven't noticed any problems in the problems view (other than the
obvious ones, haha), but I don't look at the problems view much; I rely on
the file/line markers.
Re: Persist Getter/Setter Insertion Point [message #263463 is a reply to message #263389] Wed, 20 August 2008 15:28 Go to previous message
>>>>>>> changes.
>>>>> Member.
>> report?
Bug 244716
Wojtek :-)
Previous Topic:Java editor deletes text after pause of typing
Next Topic:ganymede with webtools
Current Time: Mon Apr 23 09:53:07 GMT 2018
Powered by FUDForum. Page generated in 0.03299 seconds
